Go Back   Automotive Forums Car Chat > GMC > Terrain
Old 10-27-2023, 07:01 PM
1987ss's Avatar
1987ss 1987ss is offline
Engine not rotating with key
2010 terrain 2.4L it had a engine swap after sitting for a year. Tried to start had to reprogram key kept saying security. Did the key on engine off 3 intervals. Security light went away but engine doesn't rotate and no sound of fuel pump. If you jump starter relay the engine will rotate. Any ideas? Nothing appears unplugged or forgotten like grounds etc.. thanks in advanced for any suggestions
Old 11-07-2023, 12:06 PM
1987ss's Avatar
Re: Engine not rotating with key
Wound up being corrosion on back side of fuse block under hood.. incase someone else has a similar issue
Old 11-07-2023, 07:32 PM
Blue Bowtie's Avatar
Registered Offender
Thanks for the update and feedback.
The UEC (fuse/relay panel) corrosion, oxidation, and marginal contact problem is not limited to the Terrain. The complete Lambda platform and some trucks have experienced the same issue. It's been happening on some models since the 1990s.
Apparently, solder is just far too expensive to use in constructing critical electrical components.
