Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 08-29-2023, 10:51 AM
truck 86 truck 86 is offline
insulation in roof pillars?
has anyone used insulation in roof pillar and A&B pillars for sound and hot cold weather, help the cab from heating up in the hot sun.
either fiberglass or styrofoam peanuts or expaning spray foam, using dynamat on flat roof surface
thank on any tips suggestions or experience on the topic
1986 G body chevy has big area pillars 5" wide by 1.5 thick around the roof
Old 08-29-2023, 06:56 PM
Blue Bowtie's Avatar
Registered Offender
Re: insulation in roof pillars?
It seems reasonable, but bear in mind that even the void areas in the body can benefit from a little ventilation. Moisture can condense in a lot of places, and it would be good to be sure it can get out. Spray foam may prevent that from happening, but glass batts or peanuts may allow some air movement. Peanuts may actually move ant make noise, however.
