Go Back   Automotive Forums Car Chat > Toyota > RAV4
Old 05-05-2023, 05:41 PM
frafreg frafreg is offline
2001 RAV4 Transfer Case Seal
I see some gear oil seeping just behind the drive shaft. I think it's the transfer case seal. I replaced this seal about 10 years ago. I think the seal should have lasted longer but it is what it is.
I made sure the seal was placed in the same spot as the original seal , (not too far back) and I used some gear oil on the shaft when installing the new seal.
Besides an original Toyota seal, what is the best brand?
Is there a specific part number to use?
Are there any other tips to be aware of when installing the seal to make sure I am doing a first rate job?
Any help is much appreciated.
Thank you in advance.
Frank
Old 05-05-2023, 08:47 PM
Blue Bowtie's Avatar
Registered Offender
Re: 2001 RAV4 Transfer Case Seal
Any CR/SKF/NTN seal of the appropriate size will work. Chances are that NTN was the OEM supplier of the seal. The nice thing about the CR/SKF seals is that you can specify a seal with a dual lip, and seal contact areas in a different location from the original. This is really helpful if the shaft or driveshaft yoke has a groove wearing into its surface where the seal was riding originally.
Old 05-08-2023, 07:10 AM
Thank you Blue Bowtie for your response and for educating me on seals. Much appreciated!
Old 05-12-2023, 02:22 PM
I found 2 transfer case seals.
Which one do you think would be the best quality
Duralast $14.99 available from AutoZone
National $6.99 available from Advance Auto
Thank you.
Frank
Old 05-12-2023, 04:01 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
If it were me I'd buy National over Duralast.
Old 05-29-2023, 09:07 AM
I wound up going to Toyota for the correct extension housing oil seal. It cost $27.72 but I think it will be worth it. I didn't have a lot of luck speaking with the counter people at AutoZone or Advance Auto.
The Toyota part number for the extension housing oil seal is 90311-38090. The outer diameter is 2.30 inches and the inner diameter is 1.43 inches.
I hope this information is helpful to someone.
Do you know what the correct gear oil for the extension housing should be? I think I used 75/90 GL5 the last time I did this job but I'm not sure.
Thanks again!
Frank
