Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 04-14-2023, 05:57 PM
2010Firstimp 2010Firstimp is offline
2010 impala stall/idle problem
Engine revs erratically on idle.
Engine stops running when I slow down.
Weak acceleration
Any idea of what the problem might be?
Thanks.
Old 04-14-2023, 06:08 PM
maxwedge maxwedge is offline
A990 racer
Re: 2010 impala stall/idle problem
Any check engine lite? Lottsa possibilities, without more definitive info anything is a guess. Look for a major vacuum leak for starters.
The Following User Says Thank You to maxwedge For This Useful Post:
2010Firstimp (04-14-2023)
Old 04-14-2023, 10:43 PM
Hi Max wedge,
Yes, the check engine light turned on and popped the code P0443 which is the evac purge solenoid. Tomorrow I'll change it, hopefully that solves the problem.
Thanks for the reply
Old 04-15-2023, 12:55 PM
Blue Bowtie's Avatar
Registered Offender
Before just changing a part which may be intact, check the connector, the PCM fuse(s), and meter the resistance of the solenoid.
Old 04-15-2023, 02:41 PM
A990 racer
Agreed Blue, based on the op's symptoms, seems that would not have much affect on his condition, even if the hose was off.
