Old 07-06-2003, 12:35 AM
blade34609's Avatar
blade34609 blade34609 is offline
Question Wire Harnesses?
Hi,
I am swapping a D16A from a 90 CRX SI into my 90 Civic LX sedan.
I was wondering if they specifically made any wire harnesses that I could just plug and play instead of tryin to rewire everything converting it to MPFI.
Is there a wire harness that if you had a new SI ecu it would plug into that then into the new engine wireing harness?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 07-06-2003, 02:43 AM
fredthedragon's Avatar
fredthedragon fredthedragon is offline
Send a message via AIM to fredthedragon
i know it's not what you asked but i'm curious why you just going to a d16a?
I'm no street racer nor do want to be, my goal is a fun car... that leaves SUVs in the dust.
current car: red 90-civic-STD-hb
with dx trannie, ecu, shift knob, & rear seats.
i hate my vynil seats.
p.s. i am once again with computer, please forgive the one year leave of absence.
Old 07-06-2003, 03:24 AM
GTA's Avatar
GTA GTA is offline
Whee..
i think Hasport sold a converted to mpfi dx harness, you just pay like $200 and have to send in a stock dx and stock si harness.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 07-06-2003, 05:10 AM
91civicDXdude's Avatar
even if they made a conversion harness for the engine, you would still have to run wires from the ECU out to the engine bay as well as repin a couple plugs for the two extra injector wires. You would have to changeover the entire car harness.
Old 07-06-2003, 11:41 AM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
i think there is a fortune to be made in the wiring side of swaps... premade harnesses and whatnot... adapters, etc...
Old 07-06-2003, 11:51 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Running the extra wires is not that hard at all. If you can wire up a radio, then you can wire the ecu.
Old 07-06-2003, 12:34 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
I cant think of who sells them, but you can buy an adapter taht you can plug straight into the orriginal wire harness, and then straight into the d16 ecu so you dont have to repin it. but my friend told me it costs about 120 dollars. i will try to find a webpage for you.
Old 07-06-2003, 02:07 PM
blade34609's Avatar
thanks for the info guys.
I would greatly sppreciate it if you could find that web page that sells a adapters that allows me to just plug in. So if I had that all I need is a SI ECU.
Also the reason I am going to D16 is because I got a good deal on a Si engine out of a CRX. and anything is betta than the D15 DPFI.
At least I would be getting DPFI.
thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 07-06-2003, 02:16 PM
blade34609's Avatar
Hold on guys.
Someone told me that if I am just swapping a D16A6 SI MPFi engine into my LX car.
I will only need a SI ECU and just use the wiring harness that came with my SI engine? That way I wouldnt have to wire it differently?
I dont know if its true or not
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 07-06-2003, 02:32 PM
you need mpfi too dpfi will not work w/ the si ecu.
'09 Sante Fe SE Towing -- Wiring Harness MattInTally MY 07+ 1 12-25-2010 05:49 PM
wiring harness dougb2 Venture 1 11-06-2009 08:10 PM
FS: 2G Radio Wiring Harness & Reverse Harness david-b Classifieds 0 10-02-2006 02:18 PM
90 Si wire harness/ radio wires Hyatus '88 - '91 Civic | CRX | Wagon | Shuttlee 0 08-22-2003 08:29 AM
96 Supra Twin Turbo Wiring harness + trans harness/ automatic twinturboGS The Trading Post 2 04-18-2003 08:11 AM
