Old 06-26-2022, 09:45 AM
priceless priceless is offline
02 Buick Lesabre Custom occasional hard start, backfires occasionally, manifold exploded
02 Buick Lesabre Custom occasional hard start, backfires occasionally, manifold exploded put out fire fast
not making sense here
first off car showed no codes at all
then code P0171 and P0171 pending kept showing so replaced a few things that thought was code related
then codes show up then boom intake manifold explodes lucky put out fire fast
P1689 BUICK Code - Traction Control Delivered Torque Output Circuit
P1575 BUICK Code what is this? location of where to look for ? Extended Travel Brake Switch Circuit ?
P1133 BUICK Code O2 Sensor
P0171 Buick Code
All I have Replaced ----
Oxygen (O2) Sensors
Fuel Injector Connector
Intake Manifold
Fuel Line / Hose
Fuel Injectors
Spark Plugs and wires
Air Intake / Charge Temperature Sensor
MAF Sensor
new Fuel Rail
also did a smoke test small leak but fixed Fuel Line / Hose replaced
and a couple other things replaced
any ideas what I should look at from here
someone said fuel pressure regulator ? bad O2 sensor even though new ?
Timing Chain
any help at all is deeply appreciated Thanks
Old 06-26-2022, 04:31 PM
maxwedge maxwedge is offline
A990 racer
Re: 02 Buick Lesabre Custom occasional hard start, backfires occasionally, manifold exploded
The harmonic balancer could have slipped around the hub, also crank and or cam sensor can be be bad. Google the other codes, plenty of info out there.
Old 06-27-2022, 09:14 PM
Blue Bowtie's Avatar
Registered Offender
As Max alluded, the two are related. The crank position sensors (multiple) are behind the balancer on a '92, or at least are from my recollection.
Old 07-01-2022, 07:51 AM
Well sorry for the late response
did a compression test
1 rear cylinder is dead, 1 very week
other 4 are strong
now do I junk it
get a junk yard engine or
get 1 from autozone or advanced discount auto which I really don't care for
figure just had the tranny redone
Thanks for the advice
did put a new camshaft sensor in was going to put the crank shaft sensor in
side note has any one bought a engine from autozone and if so is it worth it and how complete are they
don't think its safe enough to drive with 4 cylinders?
Old 07-01-2022, 07:58 AM
Registered Offender
Is the low compression due to bore/ring wear, valves, or something else? It is possible the block and rotating assembly are serviceable and a valve is bent, stuck, or not opening.
