Go Back   Automotive Forums Car Chat > Buick > Terraza
Old 06-25-2021, 07:07 AM
Cozy9 Cozy9 is offline
Exclamation Lost key, need help.
Hi everyone! I'm in crisis and need help! I have lost my key fob from my 2008 Terraza, I contacted dealer and they quoted like $600. plus gotta tow the car there!!! This is way too expensive... Any cheaper solutions that anyone has come across maybe? Any advice highly appreciated! Thanks in advance
Old 06-25-2021, 07:42 AM
aleekat aleekat is offline
Re: Lost key, need help.
I don't see anyone selling a keyless entry fob for a 2008. Are you sure about the year? Everything I can find is 2007 was the last model year.
If 2007. Buy a keyfob online. Then call around to locksmiths for the fob programming.
Post back, that's what makes Forums Work.
The Following User Says Thank You to aleekat For This Useful Post:
Cozy9 (06-29-2021)
Old 06-25-2021, 08:17 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
You can source a FOB online but your only option to get it programmed is the dealer. It has to be hooked up to a Tech2.
The Following User Says Thank You to Stealthee For This Useful Post:
Cozy9 (06-29-2021)
Old 06-29-2021, 02:21 PM
Thumbs up Re: Lost key, need help.
yes 2008 ) Thank you for your help, I already found a solution!
Old 06-29-2021, 02:22 PM
thanks a lot, took me a while but finally I figured this out.
Old 06-29-2021, 02:28 PM
I wanted to post and update about what I found out.
Not a nice situation to be in and unfortunately, its expensive to get a replacement key.
This is why you should know a few things before you make your decision.
There are 3 options to get a replacement key (for key fobs and transponder keys)
1.Call an automotive locksmith- the easiest and fastest and most chances, the cheapest as well. Here is the number I used for a company that work all around, give them a call and ask hopefully they have someone in your area: 800-223-1453. If not, try a few local locksmiths to get a quote from.
2.Tow the car to the dealer.
3.Order a key online and have the dealer or locksmith cut and program it for you (if necessary).
don’t forget to mention to them all these details to make sure they have the right key for you.
1.Year, make and model of the car
2.Your exact location including street address and zip (for the locksmith to find you easily)
3.VIN number of the car located on the dashboard – very important
4.Make sure you can show them proof of ownership – otherwise they will not make you a new replacement key.
Now, maybe the most important thing, which is the cost
There are 3 main types of keys:
Non-chip keys: for older models – very old keys around 1998 and older. Most chances not relevant to you.
Transponder chip keys – have hidden chip inside – so make sure the locksmith have the tools to program the key for you.
Remote Key fob – push to start – chances are that this is the type of key you have. Very common for most makes and models made after 2010 or so.
The average cost is somewhere between $220-$400. Of course, do your research, this is only relevant for what I checked!
don’t be lazy, believe me there is a huge difference between the dealer and locksmith. And, maybe the most important thing: ASK TO GET A SPARE KEY AS WELL!
Last edited by Stealthee; 06-29-2021 at 03:12 PM. Reason: removed possible spam links
Old 06-30-2021, 08:21 AM
Blue Bowtie's Avatar
Registered Offender
Thank you for posting your results and the informaton. Hopefully this will be a benefit to others in the future.
