Old 03-27-2021, 05:55 PM
3echo9 3echo9 is offline
2004 Custom jerks when braking
2004 Lesabre Custom, 200,860 miles
Looking for suggestions on why my Lesabre jerks to the left when applying the brakes.
This was my daughters daily. I didn't know it was doing this until she announced she had bought herself a new/used car. So I took the Lesabre for a drive and noticed a pretty serious pull to the left when braking. She claims she didn't notice it..ok. It also sounded like a box of rocks were rolling around in the trunk. That turned out to be a bad shock. I just replaced those today. Fixed.
A few years ago I replaced the calipers, 2018. Had the dealer flush the brakes and bleed the brake lines because the pedal felt soft. It didn't help much.
I did a visual inspection on all four wheels looking for any fluid leaks. The pads were noticeably worn more on the drivers side than on the passenger side. Removed both calipers and regreased the caliper pins. I decided to put a new master cylinder on and then bled them again. The jerk is less noticeable but still present. The pedal still feels soft to me but I'm used to driving a newer car.
The pads on the rear still look good but they don't look like they are engaging the rotor very much as there is a good amount of rust spotting on the rotor surfaces.
I haven't replaced any of the brake hydraulic lines.
Thanks, for the help.
2005 Chevy Equinox LT 186,000 mi
2004 Buick LeSabre 200,860 mi
2011 Infinity G37x 103,000 mi
Old 03-27-2021, 06:09 PM
maxwedge maxwedge is offline
A990 racer
Re: 2004 Custom jerks when braking
Possible the right hand caliper is not applying fully, this can cause the pull to the left. Stuck sliders or a bad caliper are possibilities.
The Following 2 Users Say Thank You to maxwedge For This Useful Post:
3echo9 (03-27-2021)
Old 03-27-2021, 06:51 PM
I agree. It's almost as if the PS caliper is hanging up and allowing the DS caliper to engage alone, pulling the car to the left.
Old 03-28-2021, 01:53 PM
Blue Bowtie's Avatar
Registered Offender
A deteriorating brake hose can also hold and/or partially block brake fluid flow under light (normal) application of brakes. That can also create similar symptoms, but be sure the calipers are not hanging first.
The Following 2 Users Say Thank You to Blue Bowtie For This Useful Post:
3echo9 (03-30-2021)
Old 05-07-2021, 07:26 AM
This is a follow up.
Finally, got around to changing the passenger side caliper. That did the trick!
Now to figure out why the pedal is still soft. Had a dealer blead the system with no change. I suspect the rear disc brakes are not engaging the rotors as they appear to have surface rust even after a heavy use.
