Go Back   Automotive Forums Car Chat > Buick > Buick Classics
Buick Classics Discuss older classics here.
Old 03-18-2021, 11:09 PM
Cmatt7 Cmatt7 is offline
1970Skylark
I have a 1970 Buick Skylark that cranks but doesn’t start. Once I had checked the choke I had realized that when I pressed the gas pedal down the choke plate had opened, which it is supposed to close. Is it possible the linkage can be backwards? If you have any idea of what the problem might be please write back! Thank you!
Old 03-19-2021, 08:47 AM
maxwedge maxwedge is offline
A990 racer
Re: 1970Skylark
X Long Islander here. Do you have good spark to the plugs, will it fire if you spray carb cleaner into intake. Also what engine? Btw, welcome to the forum.
Old 03-19-2021, 09:44 AM
Re: 1970Skylark
It’s a 350-4 5.7L V8 engine, yes it does have good spark
Old 03-19-2021, 10:01 AM
A990 racer
Re: 1970Skylark
So it will start on carb cleaner? The choke will open when the throttle is floored, it should be closed when you just step on the pedal half way and release it. Quadrajet carb.
Old 03-19-2021, 10:55 AM
ctesla's Avatar
ctesla ctesla is offline
Re: 1970Skylark
yea, welcome Cmatt..
maxwedge is right.. 3 things fire any engine.. you said good spark; since you popped the accel pedal and the butterfly opened, you've got air; so maybe fuel? if spraying carb clean the 'lark fired and died? then pull that dang Qjet paper element and spray it too, as one little piece of gunk from tank or line will cork that fuel filter..
if you do spray the carb clean down the throat and it fires, and clean filter and still no go, might disconnect fuel line and see if it's getting any.. if she was stored over winter, and this is first time fire up for spring, it might be blown diaphragm in mechanical fuel pump.. hope this helps..
Old 03-19-2021, 05:00 PM
A990 racer
Re: 1970Skylark
As we can see, short on info here.
Old 03-19-2021, 11:13 PM
Blue Bowtie's Avatar
Registered Offender
Re: 1970Skylark
It is possible on a Rochester 2GC that the linkage is backward. It is also possible, but less likely, that a 4MV could have the linkage backward. However, in either case it is possible that the choke thermostatic element is wound backward if it is a carb-mounted thermostat. Those in a well in the intake are less likely to have that happen.
Old 09-16-2024, 06:17 AM
kaylanimorgan kaylanimorgan is offline
Banned
Re: 1970Skylark
I have a 1970 Buick Skylark that cranks but won't start. I noticed the choke plate opens when I press the gas pedal, but it's supposed to close. Could the linkage be backwards? Any ideas on what might be wrong? Thanks!
Old 09-16-2024, 10:03 AM
Registered Offender
Re: 1970Skylark
If the choke plate is closed with the throttle at idle, opening the the throttle to nearly full is supposed to open the choke slightly. This is a clear-flood mode, and is by design.
