Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 12-25-2020, 04:10 PM
ky wonder ky wonder is offline
Sterring issue 2006 malibu,
Have a failure in the electric power steering system on sons car
Have researched it enough to strongly think it's the torque sensor
I am capeable of doing the work
Question is this, if I buy the gm replacement sensor and install it. will it just need to have the codes flashed or will I need to have it flashed to get the power steering back up
Old 01-26-2021, 10:22 AM
Re: Sterring issue 2006 malibu,
Wasted 140 bucks on the sensor, did not fix, it was the electric motor,got a whole steering colum from junk yard for 50 bucks, from a pontiac, had to swap out the steering wheel and switch lever pack but was simple to do
Old 01-26-2021, 09:27 PM
Blue Bowtie's Avatar
Registered Offender
Thanks for the update. It's always good to see the resolution and results. Sorry you dropped the cash on the sensor, but fifty bucks for the whole column sounds like a pretty good bargain to make up for it. For under $200 you got him back on the road, and I'd hate to think what a shop would have charged, probably including the new snesor as well.
Old 02-10-2021, 04:20 PM
j cAT j cAT is offline
[quote] wonder;7226426]Wasted 140 bucks on the sensor, did not fix, it was the electric motor,got a whole steering colum from junk yard for 50 bucks, from a pontiac, had to swap out the steering wheel and switch lever pack but was simple to do [quote]../////////////////. /////////////////////////////////////////////////////////////////////////////////////////////////////// wiring and corrosion issues on these electric steering motors. dodge also had these same failures ..
