Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 06-10-2020, 03:49 PM
merrillwebb merrillwebb is offline
79 el camino transmission slipping
This problem came on suddenly. Slips in all gears. Fluid is pink.
Old 06-10-2020, 05:38 PM
Blue Bowtie's Avatar
Registered Offender
Re: 79 el camino transmission slipping
TH350? Does it also slip when manually placed in L?
The fluid is pink, but is it full? Overfilled?
Old 06-11-2020, 05:17 PM
thanks. i will check it out
Old 06-14-2020, 09:54 AM
Thx. Finally got a ride in the vehicle. Belongs to a young friend I'm trying to help. As you suggested I had him start out in low and hit the throttle good and accelerated fine then into second with nice solid shift and no slippage, same into 3rd with a nice long hill started getting an engine twitch and oil pressure drop 5psi with each twitch but would not accelerate past 70 mph, just hold its own, did not notice a passing gear, about that time we got quite a vibration so as slowing test ride was interrupted by a blow out on the right rear. Any clues so far? Thx Merrill
Old 06-15-2020, 07:08 AM
Registered Offender
If the trans is not slipping in manual ranges, the clutches and band may be O.K. The fact that the oil is still pink would also tend to indicate that there is no serious wear.
The question may be the line pressure control (modulator) and valving.
Tags
elcamino , slippage , transmission
