Old 02-02-2020, 12:21 PM
adrenalin2k4 adrenalin2k4 is offline
1992 Silverado 5.7l weird issue
I have a 1992 Silverado 5.7l with 171000 miles on it. The truck is clean and pristine, very well taken care of. Fluid changes have been made regularly. The issue is that after the last oil change was made, I would drive it about 20 miles and a tap/knock will occurs. The tap/knock isn't very loud and seems to be coming from the top rear of engine. The engine doesn't miss, run rough or running hot. Average temp is about 185 and oil pressure is about 35-40 psi. Any ideas are greatly appreciated. Thanks in advance.
Old 02-02-2020, 04:32 PM
maxwedge maxwedge is offline
A990 racer
Re: 1992 Silverado 5.7l weird issue
Well from here this can be tough. Same oil you always use? If you are sure it is a valve/upper engine noise, then try and determine which side and pull that valve cover off, look at/ listen to the valve train.
Old 02-02-2020, 07:04 PM
Blue Bowtie's Avatar
Registered Offender
Further, what brand/number/type oil filter was installed for the change? That can be critical.
Old 02-03-2020, 09:33 AM
Sorry for the delay in replying, I have a nasty cold. I went out this morning and check the dip stick and found out it is over filled by about 2-3 quarts. I also checked the sticker info and I am not very happy at all. It is a Pennzoil filter with 15w 45 which is either Delo or Rotella. I hope they didn't mess my truck up. I called the oil change place and they are out of business. What is your opinion and or suggestions. Thanks in advance.
Old 02-03-2020, 03:43 PM
A990 racer
Change the oil and filer using a quality filer such as Napa Gold. Use any quality oil of the recommended weight.
Old 02-03-2020, 05:42 PM
Thanks for the help. I am a better than average mechanic. It is sometimes better to talk to another mechanic about certain issues. I will post back with the results. My Dad bought the truck off of the showroom floor on black Friday of 1992. It was and still is a trophy truck. Real wood grain accents and the steering wheel is a wood grain Grant GT. All leather captain chairs and back seat. Still in very good shape. Thanks for the help.
Old 02-03-2020, 06:56 PM
777stickman 777stickman is offline
I agree with Max & Blue. If you can, change the oil & filter yourself, do it after a 15-20 mile drive. Let it drain for 30 mins. Napa Gold is a great filter. Fill it before install. After you add the correct amount of oil and run it check the dipstick again after an hour just to be sure it's reading right.
Sounds like a great truck. Hope it works out ok for you.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 02-05-2020, 06:07 PM
I drove it today on a 25 mile round trip and no our if the ordinary sounds. I have a doctor's appointment tomorrow and will drive it about a 60 miles round trip. I will post back and let y'all know what is going on.
I would just like to know if it being overfull or wrong oil caused it to do that. Thanks for the help.
