Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 10-18-2019, 10:19 PM
82Stang 82Stang is offline
2000 Bravada brake light on
Tried the old redneck fix of blasting down the driveway and slamming on the brakes. Did it a few times, but no difference in pedal. Got a squishy pedal, pushes down low but vehicle stops. No lights on dash, except brake light and airbag light. I can see through the rear wheels that rotors look rusty, prob not working too well. I just need to get this to pass inspection, then I can work on it as I go. Everything else works, no extra lights on and vehicle sounds pretty decent running for having 243K on it. Does a vehicle still pass inspection with the brake light on?
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 10-18-2019, 10:51 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 2000 Bravada brake light on
Have you checked your brake fluid level?
Old 10-20-2019, 07:55 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Get it scanned at a chain type auto parts store, let the computer tells us what's going on.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 10-20-2019, 08:31 PM
maxwedge maxwedge is offline
A990 racer
Chris, a scan does not look at brake warning lite issues unless it is abs related. You knew that. Lol
Old 10-21-2019, 06:59 PM
brcidd's Avatar
brcidd brcidd is offline
Either parking brake is partially engaged, or your pressure differential switch on master cylinder is activated due to seeing a massive pressure differential in line circuits. most likely due to a leak. Look for drop in fluid and drips from under vehicle to identify leak. Corrosion makes it happen.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 10-22-2019, 07:08 PM
AF - Advisor
Then you'd get an ABS light too?
Old 10-22-2019, 08:07 PM
A990 racer
Yes, if the abs lite was on, then an abs function scanner would trace the component, used by a pro of course. We are fading on these forums, not like it was.
Old 10-23-2019, 06:54 AM
Blue Bowtie's Avatar
Registered Offender
I've seen a body code for a low fluid level in the past, not linked to an ABS/traction code. In this case, I'm thinking Stealthee may have predicted the problem.
