Go Back   Automotive Forums Car Chat > Toyota > RAV4
Old 09-12-2019, 07:11 PM
frafreg frafreg is offline
2001 RAV4 - Mode $06 TID $01 CID $02 Error
Using Torque Pro I got TID 01 CID $02 error.
It says Rich to lean sensor threshold voltage constant
Max: 128 Current: 143
I did some research and for Toyota:
Both TID $01 and CID $01 relate to the catalyst monitor.
TID $01 as Catalyst and CID $01 as Catalyst Deterioration Level for Bank 1.
I got TID $01 as Catalyst and CID $02 as Catalyst Deterioration Level for Bank 2 but not sure.
Could this mean a bad downstream O2 sensor or are the catalytic converters really bad?
I also had error codes P0420 and P0430 indicating bad catalytic converters.
Any help would be appreciated. Thank you.
Old 09-13-2019, 02:13 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 2001 RAV4 - Mode $06 TID $01 CID $02 Error
It is very possible that the problem is the Sensor 2. Considering the difference in cost, I would certainly replace the downstream sensor and see if it solves the problem. I don't know of any other sensor which monitors the catalyst efficiency for the ECM other than the HO2 sensor.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-13-2019, 03:12 PM
I would like to be able to test the sensor more thoroughly before replacing it. When I reset the codes, the light stays off for almost 2 weeks. I was fortunate enough to pass inspection because it completed and passed all of the monitor tests long enough.
