Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 07-17-2019, 07:17 AM
cshults's Avatar
cshults cshults is offline
DRLs/Automatic Lights
Hi all, my drls and automatic headlights stopped working recently. All lights and turn signals work when manually turned on so I suspect a connection came loose somewhere but I can't seem to find one under the hood. Any help would be appreciated.
Thanks!
Chris S.
2001 Bravada Platinum Ed.
1992 Beretta GTZ
Old 07-17-2019, 06:52 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: DRLs/Automatic Lights
Did you check the fuses?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 07-17-2019, 07:35 PM
cshults's Avatar
Looked in the manual to see if there was a fuse forthe drl system but didn't see one listed and the fuse for just the headlamps is ok.
Chris S.
1992 Beretta GTZ
Old 07-18-2019, 07:20 PM
AF - Advisor
The DRL relay was in the glovebox on my gone but not forgotten '97 Bravada.
Blue Bowtie's Avatar
Registered Offender
...And the diode?
Old 07-18-2019, 10:21 PM
cshults's Avatar
Actually in the glove box? Never knew there were any relays in there..I'll check it out tomorrow..
Chris S.
1992 Beretta GTZ
Old 07-18-2019, 10:22 PM
cshults's Avatar
Originally Posted by Blue Bowtie View Post
...And the diode?
Not sure where that is and what I would check for. Can you give some more details? Thank you.
Chris S.
1992 Beretta GTZ
