Old 05-13-2019, 10:25 PM
hypermaxed hypermaxed is offline
ignition problems on 94 S10
i was replacing a fuel pump relay on my S10 today i double checked the part #'s and it was compatible, i put everything back together. i went to start the truck and i get nothing from the ignition no crank no click. i have checked the fuses checked the battery cables cleaned them up with a wire brush still nothing from the ignition is there something i missed ? i have not tried to jump the starter yet as i have no idea where it is on this truck lol. embarrassed to admit that. any help is greatly apperciated
Old 05-14-2019, 06:28 AM
Blue Bowtie's Avatar
Registered Offender
Re: ignition problems on 94 S10
Is this a 134" inline or the 262 V-6?
Old 05-14-2019, 07:50 AM
262 V6 Vin Z
Old 05-14-2019, 09:08 AM
just in case you wondered, no i never put the push button start on. all wiring is oem as far as i know.
Old 05-14-2019, 09:51 AM
aleekat aleekat is offline
Get a voltmeter and test your battery first.
Post back, that's what makes Forums Work.
Old 05-14-2019, 10:41 PM
ok i checked the battery 12.65V, cleaned the cables. checked voltage at the dash for the ignition its getting 11.45V i checked all the grounds i could see. all my dash lights are working it seems i am getting power everywhere but the key when i turn it to start the truck.
Old 05-15-2019, 03:25 AM
on the picture the relay i replaced is the last one on the right. looking at pictures online. should i have more plugged in?
Old 05-15-2019, 08:57 AM
So when you turn the key, do the lights dim? Did you check voltage when turning the key? Could be just coincidence that it won't crank after what you did.
Automatic? If so try starting in neutral.
Old 05-15-2019, 12:04 PM
the lights on the dash and radio shut off, i do not notice any dimming of the dome or mirror lights. when i put the truck in Neutral the key won't turn at all. key won't turn unless in park. no crank at all, i turn the key to start the truck and nothing happens. before this happened i was having issues with the truck dying and stalling out so when i had issues starting the truck one day i got a CODE 54 i looked up the problems that it could entail. so i went out and got a new fuel pump relay. before i did anything i disconnected the battery. switched the relay and hooked back up the battery. that's all
this is where i got info for the code https://repairpal.com/gm-obd-code-54
Old 05-15-2019, 03:51 PM
Doesn't take much to light a dome/mirror light. You need to connect the voltmeter to the battery and read the voltage when trying to start.
How old is your battery?
Have you tried to jump start it with another car?
Old 05-15-2019, 04:57 PM
yes i did try to jump it with another car still no crank or start .. the battery is less than 3 months old and the volts as of this post 12.50V
Old 05-15-2019, 05:20 PM
https://www.aa1car.com/library/us1296.htm
Old 05-15-2019, 05:50 PM
guess i am goin to rent a steering wheel puller tomorrow to replace the ignition cylinder
Old 05-16-2019, 02:40 AM
brcidd's Avatar
brcidd brcidd is offline
As I recall- a '94 has the ignition switch on the steering column left side- driven by a push rod- no need to pull steering wheel...
Do what I would do- turn ignition on (pink wires will be energized now) then jumper (or cross up) your red wire to yellow wire on ignition switch plug---(big heavy wires) see if starter engages- if so- the bad ignition switch, if not then problem is elsewhere- as in tranny park/neutral switch.
report back..
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-16-2019, 11:24 PM
i was not able to get out to work on the truck today. the wires i am looking for is it on the same plug in for the wipers and buzzer or another plug that i need to find?
