Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 04-15-2019, 12:49 AM
Malachias Malachias is offline
Front R/L ABS sensor
Someone at this helpfull forum can help a brasilian gay with some directions
for to get a pair of front abs sensor that fit a Olds 98 year 1991 model Regency Elite set up with Tevez ABS system?
Itīs a unique car in Brasil and a have been exaust looking for it at net and Ebay with no
luck. My last hope was at Rockauto that show up this front sensor as discontinued.
Any help will be appreciate even a junkyard indication that can send it to Brasil.
Price doesīnt matter. I need to fix my beloved buddy with 56.000ml on clock bought by me in 1991.
I let my email if necessary. [email protected]
My name - Jefferson Malachias
A lot of thanks in advance.
Old 05-12-2019, 02:05 AM
Re: Front R/L ABS sensor
Hi folks:
Almost one month and anybody for help.
Even a junkyard indication that can ship to Brasil this sensor
will be welcome.
My last hope for help itīs here.
My best regards for all
Old 05-12-2019, 07:12 AM
aleekat aleekat is offline
http://www.car-part.com/
Post back, that's what makes Forums Work.
The Following User Says Thank You to aleekat For This Useful Post:
Malachias (05-22-2019)
Old 05-12-2019, 12:44 PM
Tech II Tech II is offline
Unfortunately, this is going to be a constant problem in the future....getting electronic parts for cars from the 1985-1995 eras.....
There are plenty of rear sensors available, but not fronts......only hope is off another car, but I would doubt it would last long or even be good....
The Following 2 Users Say Thank You to Tech II For This Useful Post:
Old 05-13-2019, 07:51 AM
Blue Bowtie's Avatar
Registered Offender
If you can provide mounting dimensions and configuration, you may be able to replace the sensor with a standard, off-the-shelf proximity switch from someone like Turck. Most of these sensors are plain magnetic prox switches with or without external excitation, with a fairly low/moderate switching time, and may only require a connector change to fit the application.
Old 05-13-2019, 08:07 AM
Registered Offender
I don't suppose a '92 is the same:
https://www.1aauto.com/wheel-bearing...CABEgJECPD_BwE
Old 05-22-2019, 01:53 AM
Thanks a lot TechII.
Even a useded front sensor Iīm not founded a useded parts seller that ship to Brazil. I probabily will take a chance to buy those useded sensor . Itīs better that no ABS and about $ doesīnt matter, I wanna my ABS system back.
My car itīs very low mileage and itīs unique at Brazil.
If you can help me again with a junkyard indication that ship it I will appreciate .
Regards
Old 05-22-2019, 02:01 AM
Thanks Blue Bowtie for your sugestion.
Iīm going to verify my mounting dimensions and configuration like Ohms, pulse rates and resistance as also educate me better for to try replacement with stantard as sugested.
Agaim thanks a lot.
Regards
Old 05-22-2019, 02:07 AM
REally. Isīnt the same.
The 98 Reg. Elite at 1991 year itīs Teves II sistem.
Thanks for to try to help.
Best regards
