Go Back   Automotive Forums Car Chat > Cadillac > CTS and CTS-V
Old 02-05-2019, 01:05 PM
azakram azakram is offline
Question Extreme cold caused thermostat problem
Last week -30F degree temp caused no heat inside the car. Later I took it to the mechanic and he said thermostat is out. and it is $500 job.
I changed that sucker some years back, it is under the intake manifold and difficult to take out.
I am thinking to change or flush the antifreeze, anyone had any luck with that?
Old 02-05-2019, 02:23 PM
aleekat aleekat is offline
Re: Extreme cold caused thermostat problem
If the thermostat is stuck open, flushing etc won't do any good.
Post back, that's what makes Forums Work.
Old 02-05-2019, 04:58 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
As aleekat said if it is a thermostat problem the only fix is to replace the thermostat. With the thermostat being stuck open the coolant can never reach operating temperature. Fresh coolant won't fix that.
Old 02-05-2019, 06:21 PM
Blue Bowtie's Avatar
Registered Offender
If the 'stat didn't close at -30, it's probably never going to close. A flush to clear it out would be nearly miraculous.
BTW - It was a few degrees cooler here, and my two daily drivers stayed very low on their temperature gauges, but still well above 160°F.
