Old 07-03-2003, 10:25 PM
Bethie Bethie is offline
Send a message via ICQ to Bethie Send a message via AIM to Bethie Send a message via Yahoo to Bethie
Squeaking Noise/ help?
I am a newbie here and I have been having issues with my car and found this site. I drive a 99 mustang V6. Lately it has been making a squeeking noise around the right front wheel when i make left turns. The noise is not very loud and i haven't been able to figure out where exactly its coming from or whats causing it. I do not think it is my brakes, the usual cause for sqeeking, because me hitting the brakes doesn't affect the sound in any way. I had a look at my car today and could not find any place that wasn't getting greased or anything like that. I also checked the lugnuts on my right wheels to make sure they were tight. Any ideas as to what may be causing this little squeak??
Old 07-04-2003, 11:44 AM
rerun rerun is offline
well, seeing that its hard to pin point it out off the web, i could take a guess that it could have to do with your suspention, the front right shock perhaps. or it could have something to do with the steering, i dunno like i said its way to hard to pin point it just by reading it on a message bored, hope it helps
Old 07-06-2003, 06:50 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
You live in Ohio? I just drove through Ohio the other day, too bad I didn't have a computer with me to check this site, or I could have helped in person. Like rerun said, its hard to determine squeaks and noises over a computer. But look at the little stiff, wheel hub bearings, tie rods, grease fittings, breaks. could be a number of things.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-27-2003, 11:13 PM
princessalisse princessalisse is offline
I have squeky noises too, but I have a slightly older model. Maybe's it's just Ford Mustangs! I have a 68 coupe and it makes squeaky noises whenever I drive, especially over bumps. Let me know if you figure out what it is. Check your springs/shocks.
Old 07-27-2003, 11:51 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Squeaks you could be a million things. It's so tough to figure out over the net. If nothing when you look at the car screams at you I need to be changed or greased. Questions to think about would be how many miles have been put on the car since this was replaced(Shocks, Struts, Wheel bearings, Endlinks, etc..,). A lot of times its just a pure process of elimination when it comes to squeaks on suspension stuff.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-28-2003, 07:07 AM
94svt5.0's Avatar
94svt5.0 94svt5.0 is offline
My brothers 94 GT squeacked really bad from the passenger front wheel whenever you would turn the steering wheel or hit a bump. We though it was the ball joint, but befor we changed it out I took my wifes stethoscope and listend at each joint in the front end as my brother would bounce the car. The squeak ended up comming from the outer tie-rod end. Its best to try to narrow the source, fooling with the various front end parts can be a pain.
More photos and Info/website!
1994 Cobra
-off road h-pipe
-superchips power chips
-mac cold air induction
-BBK aluminum underdrive pullies
-pro-m 75mm bullet MAF
-18" konig wheels with nitto 555 zr tires
-Ford Racing 65mm throttlebody
-Ford Racing king cobra clutch
-Ford Racing 3:73 Gears
-Ford Racing Aluminum driveshaft
-Bullit suspension/ springs,shocks,struts
-Aubrun HD limited slip Diff.
2002 subaru Impreza RS
- stock
1989 Toyota pickup 4x4
-K&N
