Old 07-18-2018, 03:09 PM
pirata12's Avatar
pirata12 pirata12 is offline
Paint blistering
Hi all
Haven't posted in some time but will soon.
I'm having a massive problem with paint blistering. The primer did it, so I sanded and cleaned properly and reprimed. Still blistered.
Sanded and tried to spray the paint colour on directly with the same result.
I've cleaned the plastic thoroughly and am now out of ideas.
Old 07-18-2018, 07:03 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Paint blistering
Details, man.
What kind of paint, what kind of primer, how are you applying them?
Got any pics?
PHOTOBUCKET SUCKS
Old 07-18-2018, 10:50 PM
360spider's Avatar
Agree with Andy - first of all, what are you painting - plastic, resin, metal?
What primer, what paint, etc.
ItalianHorses.net
Old 07-19-2018, 04:59 AM
pirata12's Avatar
Sorry about this. I can't seem to upload pictures. Says invalid image file. I'm using jpg and jpeg. bmp also didn't work. Sizes are small too.
I'm painting an Italeri Plastic kit. The tank went perfectly. The fairing is a disaster.
I'm using Tamiya spray paints. The Surface Primer and the Silver Leaf (TS-30).
I've done this a number of times and never seen this happen.
Once sorted, I can post WIP. Trying to sort the poor join lines and get the body sorted.
Thanks.
Old 07-19-2018, 09:21 AM
360spider's Avatar
Hmm, seems like this should be pretty straightforward then. One thing that I would suggest in this case, maybe try different can of paint/primer? How old are they? Did you use the same cans to paint the tank?
PS: I flickr to post pix. Works great.
ItalianHorses.net
Old 07-19-2018, 12:43 PM
pirata12's Avatar
I'll upload later tonight. The odd thing is I'm using the same cans right now on a die cast restoration with no issues.
Old 07-19-2018, 01:06 PM
360spider's Avatar
Its definitely the surface you are painting then, it usually is.
Does it do it all over, or just in certain spots?
ItalianHorses.net
Old 07-19-2018, 01:52 PM
pirata12's Avatar
Just in spots 360 spider. I figured its the surface, but cleaning it has yielded no positive results.
Old 07-19-2018, 05:00 PM
stevenoble's Avatar
What are you using to clean the plastic before painting?
Steve Noble
Old 07-20-2018, 02:46 AM
pirata12's Avatar
Plain water. I try avoid anything with soap and chemicals.
What's interesting is that it blisters immediately. As the primer or paint goes on I see it happening.
Old 07-20-2018, 04:35 AM
Kjenjak's Avatar
Kjenjak Kjenjak is offline
Arre there residues of enamel paint on the part? They react with wet Tamiya paints imediately.
Or oil or grease?
I never had issues with soap and Tamiya TS paints.
I'd wash the parts thoroughly with soap and water to remove anything that shouldn't be there.
<img src=http://www.automotiveforums.com/vbulletin/image.php?u=698755&type=sigpic&dateline=1361304198 border=0 alt= />
Old 07-20-2018, 06:43 AM
pirata12's Avatar
Or oil or grease?
I'll have to give the part a good scrub it seems. There shouldn't be any residue of anything on this as it's straight out the box and all the other parts are fine. I also can't see anything untoward.
I'll try the soap an water and advise.
Thanks guys.
Old 07-20-2018, 07:17 AM
freakray freakray is offline
AF Modelrater
Just try your regular Sunlight soap and let the parts air dry thoroughly.
Typically parts have a mold release agent on them, often it can be little enough to not be an issue but in some circumstances it can be enough to cause paint issues.
AF User Guidelines
The Following User Says Thank You to freakray For This Useful Post:
360spider (07-20-2018)
Old 07-21-2018, 01:25 AM
stevenoble's Avatar
I use panel wipe same as used in auto body shops. Just wipe on with some tissue and it evaporates. It will clean any contaminants from the surface. You can use soap and water, but I find the panel wipe quicker as there's no drying time..
Steve Noble
Old 07-23-2018, 05:44 AM
pirata12's Avatar
I was wondering if something like benzene would work and then let it evaporate properly?
