Go Back   Automotive Forums Car Chat > Toyota > RX300/RX330/Harrier
Old 07-08-2018, 04:43 AM
FTI FTI is offline
Transmission issue
Hi, my rx 300 sometimes not engaging in gear 4. Any possible cause will be appreciated. The filter was replaced in October last year. Thanks.
Old 07-08-2018, 12:07 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Transmission issue
It won't normally engage 4th gear if the engine is cold or you are driving very slow. If the problem occurs when you are driving normally, then it may be your engine coolant temperature sensor is bad. If this is the case, your computer thinks that your engine is always cold and doesn't allow up-shifting to fourth gear. Test your coolant temperature sensor.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 03-23-2020, 04:54 AM
gewone's Avatar
gewone gewone is offline
Also, unfortunately, the RX300 gearbox has a tendency to break at semi-high mileage. How many has yours got?
