Old 04-29-2018, 08:20 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
slow to start and other things
my 93 3.1L had been running a bit rough so I took it to my mechanic where it sat for quite awhile. He was leery of fixing what he thought was wrong because he said that [whatever it was] is easily broken when working on it. It was a sensor or something, I really can't remember.
It's just very sluggish to drive, lacks power, almost shakes.
It also has to be jumped in order to start. It has to sit, connected to another vehicle for a good 5 minutes, but will eventually start, but is very slow to start, you can hear it turning over several times before it finally starts. Does this sound like the starter is going out as well as a battery that needs replacing?
Thoughts on the running rough? Clogged cat. perhaps? Sorry I can't remember what my mechanic originally said, just that it has a tendency to break when working on it (could be because my car is so rusted out LOL)
This ain't your grandma's car!!
Old 04-30-2018, 07:05 AM
Blue Bowtie's Avatar
Registered Offender
Re: slow to start and other things
If the starter is cranking the engine too slowly, that can indicate a weak starter, excessive engine friction (drag), or low voltage. If the voltage is low, starting may take several revolutions since spark energy and injector operation would also be affected. If there is excessive engine friction that may be related to the rough running. It could be related to the hard starting. or it could be coincidence.
Old 04-30-2018, 08:17 AM
Schurkey Schurkey is offline
Your "mechanic" is an idiot. Find someone else. Pretty-much ANYONE else.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 04-30-2018, 08:06 PM
Tech II Tech II is offline
I agree with Shurkey.....
It sounds like you have several things wrong with the vehicle........
First thing, make sure your bat cable connections are clean and tight...then you are going to have to have your battery and charging system tested, as Blue suggested....
But you are on a slippery slope here.......25 year old car.......to fix or not to fix, that is the question....it can easily become a money pit.....
