Old 07-03-2003, 04:53 PM
civ69's Avatar
civ69 civ69 is offline
Send a message via AIM to civ69
a\c question
Does anyone have a 92 civic with R-134a a/c. If so could you tell me the number on the compressor, it should start with TRS or TRF, and the model number. I was told that any 92-95 compressor would fit but the fittings are different, so Im trying to find out which compressors came on 92 civics....
Thanks
Old 07-03-2003, 06:35 PM
94civic's Avatar
94civic 94civic is offline
if your car isn't converted to r-134a the fittings will be different. just go buy a conversion kit at autozone or something and you should be all set.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 07-04-2003, 06:37 AM
zippeay zippeay is offline
No he's talking about the actual lines, I've heard that too. Take it to a honda dealer and ask them, you don't have to buy it from them just get the part number. All the R-134 adapter does is connect to the top of the condensor.
Old 07-04-2003, 09:28 PM
civ69's Avatar
Exactly zippeay, the only thing the conversion kit does is change the service ports. I guess I will have to go to a dealer to get the model number for the compressor.
Old 07-05-2003, 11:15 AM
I know there are two different kinds, I had to do the same thing when I hooked up my A/C. I know one kind is a Nipodenza and I don't remember what the other one is. Well good luck
Old 07-05-2003, 11:17 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the two choices were Nippendenso and Sanden, you cant mix the two compressors either, so if you have a sanden compressor you need another sanden, cant use a nippen.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-08-2003, 01:16 AM
civ69's Avatar
Heres what I found, a list of sanden a/c compressors for civics..
CIVIC APPLICATION INFO COMP TYPE CLUTCH TYPE
1999-96 All W/L4 1.6 Eng. (Model #4955) TRS090 4 Groove
1995-94 All W/L4 1.5 Eng. (Model #3057) TRS090 4 Groove
1995-94 All W/L4 1.6 Eng. (Model #3057) TRS090 4 Groove
1993-92 All W/L4 1.5 Eng. (Model #2050) TRF090 4 Groove
1993-92 All W/L4 1.6 Eng. (Model #2050) TRF090 4 Groove
Old 07-10-2003, 06:04 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
I just had converted mine to R-134a, my buddy actually did it for me free of charge when swapping in my engine. Of course, my AC has always sucked ass, so I don't know. It's converted correct though, so my not-very cool (as in room temp most of the time in the hot summer) AC must be a different problem. Sometimes it gets cool quick, other times the damn thing doesn't seem to blow cool air. Sometimes after driving for a 20 minutes the cool air stops and it's warmer air. Do you think it's the compressor? I can't imagine I need to re-charge it with more R-134a. It got converted and re-chaged with it last summer, and got a new compressor o-ring at the same time. Any Ideas?
Old 07-10-2003, 08:51 AM
Sounds like the compressor, or mabey your belt is loose. Its hard to tell, does the compressor ever make any noise? If it squeels sometimes the bearings are probably shot in it.
Old 07-16-2003, 01:42 AM
Honda God
Thanks for the info Zippeay. I think the it's the compressor making a little noise, but I could be wrong. I'll turn down the stereo and listen more closely next time If it is the compressor, are those expensive to replace? like how much money are we talking to do it?
Old 07-16-2003, 03:54 PM
$422.00 at www.hondaautomotiveparts.com brand new, or you can go to a junk yard but you run the risk of having it not work at the junk yard. Thats a really good price from that web site trust me normally their like 600.00
Old 07-17-2003, 01:21 AM
Honda God
Thanks Zippeay. I think I am gonna make sure that it is indeed the compressor first. I want to make sure that's the problem or the only one before I go shelling out $422 or $600. I had a feeling they were that much, but I was hoping otherwise. Of course, it might be a little while before I can afford $422 or $600. With my luck by the time I do winter will be here, lol. I guess then I won't have to worry out my a/c doing only intermitant cold air, lol.
Old 07-17-2003, 11:30 AM
A/C's only a restriction on your car anyway, who needs it, lol. I say that and its like 1,000000000 deg. here right now. Would be nice to have it now, I dumped my A/C actually I just never hooked it up again when I did my swap. Anyway good luck
Old 07-18-2003, 03:56 AM
Honda God
I know what you mean about A/C being a restriction. After I did my swap, I was going to the coast with my girlfriend, and had the A/C on. It was one of the not so- often times it was actually blowing cold air, lol. Which was good cuz it was hot as hell that day. Anyways, we come to the coastal mountion pass, and as I am going up, I am thinkin, damn, my engine is bogging, WFT?? I was trying to pass this car, and I was going ok, but not like it shoulda been. She's like, click...turns the A/C off, and the car took off. It made a huge difference in power and torque. I had no problem getting past the car then. I had forgotten I had it on, since I don't use it all too often. But, damn, the difference having it "off" made. I suppose it would be a little more of a difference if I had just damned it. But at the time, It seemed like a good idea to keep it, since I was getting upgraded to r-134a for free. I suppose if it worked better, I might use it more, lol.
Ac Compressor Question bbaker1985 Grand Prix 14 08-02-2011 04:45 PM
AC Question. AC Compressor!! kaimanson Prelude 5 06-03-2005 11:21 PM
AC Question bedford 3 Series 1 04-23-2003 01:21 AM
02 AC question migojoe Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 04-21-2002 03:56 PM
Technical AC Question Rice-Rocketeer Engineering/ Technical 3 02-12-2002 11:57 PM
