Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 05-25-2005, 10:43 PM
kaimanson's Avatar
kaimanson kaimanson is offline
Unhappy AC Question. AC Compressor!!
Sometimes when I'm driving my prelude with the AC on, I can hear and feel the ac compressor going off and on continuosly (like every 20 second). maybe some moisture in the system?, old dryer/receiver?, is that normal?. PLEASEE HELPP!!
01 Nissan Sentra SE 2.0 - 121k
Old 05-26-2005, 05:40 AM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
That is called short cycling. You are low on freon. The good thing is that the compressor is working. You will have to have the AC system filled and have die added so that you can find out where it is leaking from
Old 05-26-2005, 06:16 AM
kaimanson's Avatar
Unhappy
Thank Sofast, I'm not sure about that cause I took it to a AC shop and the guy told me that the system was even overcharged ( I know they are always liar jejeej). I don't know if when it's overcharged does the same thing as when it's low on freon. I put a new ac compressor a few month ago, but didn't change the dryer/receiver. can that be the problem?
Old 05-27-2005, 04:19 PM
lorunner lorunner is offline
Re: AC Question. AC Compressor!!
An overcharged system will make the compressor cycle fast and there may be low idel with it two because the system is straing to turn the compressor.
Stop asking me about radio codes I cant get them anymore!!!
Old 06-03-2005, 04:43 PM
joellthomas joellthomas is offline
The drier desecant bag can burst and cause all kinds of problems. Does the sight glass look extreemly milky. An over charge will cycle the compressor on high pressure, and damage the compressor. If over charged there want be any bubbles in the sight glass. You need gauges.
Old 06-03-2005, 11:21 PM
kaimanson's Avatar
Lightbulb
I'm planning on changing the dryer and compressor. Cause I change the compressor a few month ago (used), but didn't change the dryer. :-( and the problem is getting worse...and the summer is arriving..
