Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 02-22-2018, 11:52 AM
Charbear Charbear is offline
2002 Avalon Shift Cable Issue
I have a 2002 Avalon with what I believe is a shift cable issue. Not sure if it's on the top or bottom side. I'd like to inspect the top (where the cable attaches to the shifter). Does anyone have step by step instructions on how to remove whatever I need to remove so I can see if the cable bushing is bad or has slipped off of the shifter? I got things partway disassembled but am not sure where to go from here. I went looked thru AllDataDIY and could not find instructions. Thanks!
Old 02-22-2018, 08:30 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 2002 Avalon Shift Cable Issue
https://drive.google.com/open?id=12a...XtD8SqDoxqqmW-
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 02-23-2018, 05:37 PM
Thx Brian! guess that means I need to do at least a partial disassembly on the dash. I saw the blow-up/break-out but sure wish there were step by step instructions. Hopefully someone will chime in. Otherwise, I'll try and muddle thru. Sorry if I missing anything obvious. Thanks again!
