Old 02-16-2018, 05:04 PM
l1driver l1driver is offline
Send a message via AIM to l1driver Send a message via MSN to l1driver
Whining noise
I have a 00 Silverado Z71, 4.8. 6 inch lift running 305/70/16 tires. Truck has 319,000 miles, original motor with I asked 4l60e transmission.
I recently noticed a whining noise that sounds like it is coming from the left front area.it seems to start around 20 mph. It I'm really noticeable when the windows are up. I've had my head out the window at 50 mph and can't hear a thing. But when I roll the window up it is very pronounced. Anyone have any ideas?
Old 02-16-2018, 10:58 PM
Blue Bowtie's Avatar
Registered Offender
Re: Whining noise
Hub bearing, front axle (carrier and pinion bearings), brake rotor, and numerous other guesses.
Old 02-25-2018, 07:16 PM
j cAT j cAT is offline
Re: Whining noise
most likely a bearing.... if the drive train has no leaks then my guess is the hub bearing.....
when I do my brakes front.. I remove the rotors and the speed sensor then I give the hubs a good amount of grease pumped into the sensor hole..
if the grease looks bad then that sure may be it.. if after you grease it and it is fixed or reduces now you know ..
I did this before many years ago and I got 4 months out of it till I had the parts/times to do it...
