Old 07-03-2003, 01:39 PM
mengy mengy is offline
D series and B series compatiblity
Would you be able to use an intake manifold from a b18b1 on a d15b7 motor? I think I've seen B series headers used on D series but I'm not sure on the Intake manifold... would I see any increase in performance over the stock d15b7 intake manifold?
I know this might be going too far but what about trannys? The reason I'm asking if because I might be getting an LS motor without the tranny from a friend of mine
Old 07-03-2003, 04:40 PM
candlaudio candlaudio is offline
Send a message via Yahoo to candlaudio
ok well believe it or not you are right about the header cause i have a d15b7 engine and i have a b18 header on there, now i bought the car like that so i dont know what the increase is but i know it is good cause i have alot of get up and go, but as far as the intake i dont know but when you find out i would like to know so i can get one myself...
Old 07-03-2003, 06:39 PM
94civic's Avatar
94civic 94civic is offline
no intake manifold, header or tranny from a b series will fit a d series without major modification and fabrication
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 07-03-2003, 07:32 PM
well actually i may be wrong but i think that the trannies wont match cause the b series is cable clutch and the d is a hydrolic..but like i said i could be wrong, i thought i read something about that one time but hell who knows these days....
Old 07-03-2003, 07:54 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Nothing between the B and D series are compatible. D and B series trannies both come in cable and hydro. That's not why they are not interchangable.
Old 07-03-2003, 07:56 PM
B16EJ1's Avatar
Are you sure that you have a B series header on there? The bolt patterns aren't even the same on the head or the cat.
Old 07-03-2003, 08:10 PM
well you know now that i think about it i did buy the car from a lier, i mean he even told me it had a chip in it but when i looked at the ecu there was not a chip in it at all, so all in all i think i have been screwed, but anyways the only thing i cant understand is the guy moved the o2 sensor from the side to the bottom which is causing a problem, so im gonna get a new header for it.... I STAND CORRECTED ON THE HEADER THAT I HAVE...oh well
Old 07-05-2003, 12:19 AM
undergroundimports undergroundimports is offline
maby
about the manifold I wouldnt mess with it I dont think it will fit. As for the tranny I believe you can contact kennedy racing products. They make engine adapters for almost anything. like a 350 in a vw golf or something they make an addapter plate that would allow you to butt up the engine and tranny. so give it a try. good luck
Old 07-05-2003, 09:50 AM
dreemkill dreemkill is offline
Send a message via ICQ to dreemkill Send a message via AIM to dreemkill Send a message via Yahoo to dreemkill
why bother?
Originally posted by fakirone
.... Nos this, nos that, my 10 second nossy nos will nos your nos.
Originally posted by Prelussion
And then both of you guys w/ you sewing maching powered cars get passed by a moped w/ a 5hp Engine and he goes on to put 5 car lengths on you. Racing an EX vs a DX is like a 10 speed bike vs a golden retriever.
AF Upstate Crew -- Member #1
Current Audio: none. car dead.
Old 07-05-2003, 05:42 PM
Options Options is offline
Send a message via AIM to Options
Yep, i think TB's will fit though.
Its not how fast you go it how fast you finish.
Second place is the first looser
Skunk2 Coil-overs
Aem 2 piece intake
Tanabe Exausht
Throttle Body coolant bypass
Apexi SAFC 2.
Skunk 2 cam gear.
ZEX dry nitrous system: currently 55 shot.
Best 1/4 Time:
16.402 @ 82 M.P.H w/ 2.290 60ft w/o spray 14.8@94 MPH w/ spray
Old 07-06-2003, 12:43 PM
94civic's Avatar
you are right on that one cause i had a d series tb on my b16a for a while cause the original b16a tb was messed up.
too much to list
Old 07-06-2003, 03:56 PM
Yeah the only reason i know, is because im swapping my stock tb and intake mani, with a b16 tb, and z6 intake manifold, which will turn it into a sidedraft, instead of down draft like my current stock setup.
Skunk2 Coil-overs
Aem 2 piece intake
Tanabe Exausht
Apexi SAFC 2.
Skunk 2 cam gear.
Best 1/4 Time:
diffrence in HP series 1 and series 2 3800SC DarkGP Grand Prix 13 01-25-2007 12:22 AM
VG30DE and VG30DETT compatiblity? 1viadrft 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 6 12-02-2005 12:09 AM
Need A B-series And D-series Swap Done? And Mechanical Problems... Nj Area NA97GSR Classifieds 0 03-28-2005 09:16 PM
Few more chops: BMW 5 Series and Ford Escort and Mazda juki86 Graphic Manipulation 3 02-18-2003 01:28 PM
