Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 11-30-2005, 10:46 PM
1viadrft's Avatar
1viadrft 1viadrft is offline
Question VG30DE and VG30DETT compatiblity?
What parts can be swapped?
Plenum?
Crank-shaft?
Rods?
Block?
etc.?
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC
My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105
Old 12-01-2005, 12:48 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: VG30DE and VG30DETT compatiblity?
i believe it's all exactly the same aside from the pistons..
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 12-01-2005, 03:08 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
ahh...here we go.
it will be easier to list the differences.
oil squirters: the TT engine has oil squirters pointed at the pistons to provide better cooling/lubrication to the pistons.
Pistons: pistons are obviouly different to drop the compression to 8.5:1
Head parts: the heads themselves are the same but the internal parts are much different. the TT valves are made out of a different metal and i am pretty sure the cams have different specs (dont quote me on this).
on a side note: it may be okay to leave the N/A heads. that you will have to research.
fuel injectors: obviously the TT has 370cc injectors while the N/A is 259cc.
i am also pretty sure there are different passages and such on the TT block that are opened up for different flow and cooling purposes. you will have to make sure of this.
dont forget oil cooler feed and return lines and getting the coolant and oil lines to the turbos. this if your thinking about what i thin your thinking about.
ZedEx Crew Member #4
Old 12-01-2005, 10:22 PM
MikeMan MikeMan is offline
Banned
Send a message via ICQ to MikeMan
IIRC the exhaust cams are different but the intake cams stay the same. The exhaust cams close sooner, leaving less overlap probably due to the higher backpressure. Otherwise, too much exhaust would stay in the cylinder for the next cycle.
Yeah it will work from a technical point of view (it will fit and it wont harm the rest of the engine), but the TT heads will probably give a bit more power (as a result of this cam difference).
As a side note, does anyone know what the oil 'holes' are for on the conrods (both TT and NA i presume). They're just above the big end bearing (EM-48 in the service manual). Would this be to lubricate the big end bearing journal?
-Mike
Old 12-01-2005, 10:44 PM
1viadrft's Avatar
You never know what crazy plan I'll come up with next, y'know?
Thanks for the replies, guys!
Old 12-02-2005, 12:08 AM
Z Cars Fanatic
Re: Re: VG30DE and VG30DETT compatiblity?
-Mike
that sounds right.
thanks form the confirmation about the heads. i wasnt sure but i was pretty sure somethind was different with the cams.
Old 12-02-2005, 12:09 AM
DeleriousZ's Avatar
riiight... i actually did know that... i guess the knowledge went into hiding for a while lol.. been slacking on my z32 stuff lately..
