Old 12-10-2017, 04:54 PM
saints0513 saints0513 is offline
2003 Sonoma won't start
Yesterday I started my truck to warm up, since it was cold outside, went back out about 5 minutes later, it was off. Tried to start it up, it cranks but will not start. Dash lights up, everything seems normal except starting it up to drive. Battery is about 2 months old, I have good voltage, it was running fine all week, no issues, but now, it nada. Which direction should I look in?
THanks.
Old 12-10-2017, 05:47 PM
harleyguy harleyguy is offline
Re: 2003 Sonoma won't start
Check spark and for fuel psi... on second thought a few years back I had a Lexus show up on a tow truck same problem you have. Check to see if it has fuel.
Old 12-10-2017, 06:54 PM
it has fuel, and it isn't giving me any codes.
Old 12-10-2017, 09:22 PM
Blue Bowtie's Avatar
Registered Offender
It has fuel, but what fuel pressure? Without the minimum 56 PSIG you can forget about it ever opening the injectors.
The Following 2 Users Say Thank You to Blue Bowtie For This Useful Post:
Tech II (12-11-2017)
Old 12-11-2017, 08:37 AM
Tech II Tech II is offline
Spray carb cleaner into the intake, and then try to start....if it almost starts or starts and then dies, you know it's a fuel delivery problem.....
As Blue Bowtie says, you may have pressure, but not quite enough....if you sprayed carb cleaner and then it started and continued to run, then the first thing I would do is replace your fuel filter.......if that doesn't take care of it, then it's a possible pump....
Old 12-11-2017, 06:36 PM
sprayed the fluid in the intake, started up and then immediately died. And I replaced the fuel filter yesterday.
Old 12-11-2017, 06:45 PM
Check fuel psi
Old 12-13-2017, 03:06 AM
brcidd's Avatar
brcidd brcidd is offline
Listen for fuel pump to come on- put ear to filler tube when ignition is turned on. Should hear it run for 2 sec and shut off.
If not-- the have assistant run starter while you lay on ground and whaaaaaaaap fuel tank with palm of your hand several times. If fuel pump comes on and engine starts, you have just diagnosed your worn out FP.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 12-14-2017, 08:05 PM
I got my wife to crank it while I hit the tank, first time it seemed like it wanted to start, the second time it did start. It ran for 10-15 seconds, then died.
Old 12-15-2017, 01:08 AM
brcidd's Avatar
It'd be real good to have pressure gage attached and let wife watch it--Probably died after pressure dropped- indicating a bum FP.
When I change a FP on a pickup I use my engine hoist to lift front of bed up 2-3 ft, no need to drop tank that way- just take out six bed bolts, no need to unhook electrical to taillights if you do it right- be careful not to stress electrical lines though. Easier to change FP sitting up then laying under truck. Lines to tank are easier to unhook, not stressing them etc. Just need to blow dirt off top of tank etc...
'99 GMC Yukon
Old 12-15-2017, 04:19 PM
got a new fuel pump last night, just got the bed lifted and braced, I agree, it will be much easier than dropping the tank and doing it. I appreciate everyone's help and suggestions, thanks.
