Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 09-20-2017, 03:06 PM
Empresive Empresive is offline
Pinion seal
Was wondering can anyone help me figure out if the pinion seal needs replace cause I always have to put gear oil in the rear end cause it goes low and there's always fresh oil underneath as well here's a couple pics
Images
http://pixady.com/image/0ays
http://pixady.com/image/0ayt
Old 09-20-2017, 10:25 PM
Blue Bowtie's Avatar
Registered Offender
Re: Pinion seal
Quite likely a pinion seal. The question becomes why it failed. If the pinion is tight (has no excessive play) a new seal may be all that is necessary.
If the pinion is loose (has measurable play) a new seal won't solve the problem. The pinion can become loose from bearing wear, a damaged housing, or from heavy load in the reverse direction (compresses the crush sleeve).
Old 09-20-2017, 11:51 PM
Re: Pinion seal
Well it's been like that ever since I bought it 9 years ago and over the years I always ended up checking the gear oil every once I awhile. I'm going to guess there is more going on with it then.
