Go Back   Automotive Forums Car Chat > Toyota > LS400/LS430/Celsior
Old 03-27-2017, 07:21 PM
daviejj daviejj is offline
1994 Lexus Ls400
I have a 1994 Lexus Ls400 with 125, 00 miles on it. Recently the cruise control stopped working. The cruise light on the dash lights when you push the control lever on the steering column. Can anyone advise as to the problem?
Warm regards,
Ron
Old 03-27-2017, 09:56 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 1994 Lexus Ls400
Check the electrical connector on the cruise control actuator which is attached by a cable to the throttle body.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 03-28-2017, 09:32 AM
Thanks Brian. The cruise control stopped working when I replaced the MASS AIR FLOW SENSOR. Would this have anything to with the cruise not working?
Old 03-28-2017, 04:18 PM
Brian R.'s Avatar
Resident Chemist
Not directly, but you may have had to disconnect the electrical connection I mentioned in my previous post, and forgot to reconnect it. Or it may have been jostled loose and needs to be pushed into place more firmly. It is the obvious and easiest place to start troubleshooting.
Old 03-28-2017, 08:13 PM
I made a fast check and didn't see the connection. Maybe I have to remove a cover. Thank you very much.
Ron
