Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 02-08-2017, 07:29 PM
joeshannallie joeshannallie is offline
1999 Venture Rack and Pinion
Does anyone have a clue or know how to remove and replace the top stem seals of the rack and pinion? I have the snap ring out but I have no clue what to do next. Please reply soon.
Old 02-09-2017, 05:09 AM
Blue Bowtie's Avatar
Registered Offender
Re: 1999 Venture Rack and Pinion
I believe the rack may need to be removed to replace the stub shaft seal. The lower cover, lash adjusting nut, and upper clip need to be removed, then the stub shaft and rotary valve assembly needs to be pressed down only far enough to permit removal of the seal and bearing parts. Replacing the seal may be fruitless without replacing a worn bearing (sleeve) since the shaft will deflect and allow oil to leak right past a new seal.
Old 02-09-2017, 06:19 AM
Registered Offender
Here is the procedure from the manual:
http://www.wwdsltd.com/files/1999VentureRackRepair.pdf
Old 02-09-2017, 12:13 PM
Thank you! May I ask where you pulled the instructions from? I have looked everywhere.
Old 02-09-2017, 09:39 PM
Registered Offender
I have a subscription service.
Old 02-12-2017, 10:48 AM
Tech II Tech II is offline
If you really don't know what you are doing, stop.......
Just replace the rack.....you can be opening up a whole can of worms here.....
Old 02-12-2017, 06:04 PM
Thanks for the advice. Thats what I am leaning to. Love the challenge but I am at the point to say the heck with the challenge and lets go the easy route.
