Old 10-31-2016, 06:53 AM
gpmodelj70 gpmodelj70 is offline
97 PA Ultra losing Trans Fluid
My 97 PA Ultra loses a pint of trans fluid every 50 miles...no leaks on the ground...looking at pan on trans it is dry...replaced radiator because the coolant had a strawberry color (thought trans fluid cooler was leaking into coolant)...did not help...WTF?...where could it possibly be going?
Old 10-31-2016, 08:00 AM
maxwedge maxwedge is offline
A990 racer
Re: 97 PA Ultra losing Trans Fluid
If you had an intermix, that stuff is throughout the entire heating and cooling system. Anyway, may have a vacuum modulator, look for fluid in the hose. Also axle seals.
Old 10-31-2016, 10:32 AM
Thanks for the reply...The car has a 4T60-E I believe so no modulator valve...no leaks on the ground...seems like I would be able to see axle seals leaking that much fluid, but I will check into that.
Old 10-31-2016, 04:08 PM
A990 racer
Some of those early year units did have a modulator, check it.
Old 10-31-2016, 04:18 PM
Thanks...but I checked the vin # with a dealer and they confirmed no modulator valve
Old 10-31-2016, 06:28 PM
Blue Bowtie's Avatar
Registered Offender
My manuals say a modulator exists through 1999. Instead of asking the dealer, open the hood and look on the front of the transmission, just behind the left radiator fan.
See a vacuum line?
Old 10-31-2016, 06:53 PM
A990 racer
Thumbs up Re: 97 PA Ultra losing Trans Fluid
See a vacuum line?
You beat me to it by 5 minutes. Lol
Old 10-31-2016, 08:11 PM
Tech II Tech II is offline
If for any reason, you think coolant made it's way into the trans fluid, you need to do a complete flush...
Old 11-01-2016, 06:25 AM
I will go and look for the modulator valve, but the car supposedly has a 4T65-E.
Old 11-01-2016, 06:32 PM
Registered Offender
Well THERE'S a first. Usually I'm still hunting for the comma key while you've posted three replies and have the problem solved.
Blue - 1 / Max - 1,001. Better look out - I think I'm catching up now!
Old 11-02-2016, 12:09 PM
A990 racer
Lotta fun for sure!!
Old 11-02-2016, 05:01 PM
4T60's had the modulator, 4T65's didn't...
Old 12-12-2016, 10:28 AM
It was the radiator...replaced it and problem solved.
Old 12-12-2016, 08:14 PM
Registered Offender
Thanks for the update. It's always good to get to a conclusion.
Old 12-18-2016, 09:15 AM
Foolzrushn Foolzrushn is offline
Goes to show how important good info is in an initial post. Was it wrong? Was the radiator replaced twice? Did the trans get flushed? Who knows.
1998 Park Avenue Ultra
