Go Back   Automotive Forums Car Chat > Buick > Regal
Old 09-10-2016, 07:11 AM
Jrcarswell Jrcarswell is offline
Ticking, loss of power 99 Regal LS
My Regal makes a ticking noise from the front left and when accelerating it can't go past 2-2.5k rpm. when the spark plugs were pulled they were running lean. Is this a fuel, spark or electrical issue or is the internal?
Old 09-10-2016, 07:30 AM
maxwedge maxwedge is offline
A990 racer
Re: Ticking, loss of power 99 Regal LS
Ticking noise from the engine? CEl on, any codes? Not enough info here.
Old 09-10-2016, 10:10 AM
There is no CEL, No codes, the noise doesn't sound like a knock but more like detonation, spark knock or lifter tick. increases with speed and i can smell gas when i open the oil fill tube.
Old 09-10-2016, 12:34 PM
A990 racer
Tough to diagnose from here, for sure don't run it with contaminated oil. Sounds like you are running so rich fuel is getting into the oil, high fuel pressure, bad fp regulator, one or more bad injectors, clogged cat, are possibilities.3800 or 3400?
Old 09-10-2016, 04:25 PM
3800 Series 2 VIN K. I have 2004 Lesabre for parts. I put a screwdriver up to each injector and the pulse is fine but i know that doesn't tell everything so i pulled the fuel rail from the Lesabre. EGR Valve, Coil packs, whole exhaust system. I'll pull the fuel pump out tomorrow if this doesn't solve it
Old 09-10-2016, 05:01 PM
Tech II Tech II is offline
Try this LIGHTLY accelerate from a dead stop.......if you can get the vehicle up to 50 mph gradually, and the car shifts ok, then stop......
Now from another dead stop, REALLY LAY INTO THE ACCELERATOR.....if the car bogs down, doesn't upshift, and rpm's top out at 3K, chances are your cat if plugged.....
You can verify this by creating an exhaust leak between the exhaust manifold and the exhaust pipe(loosen the flange nuts so there is an air gap/leak)...the exhaust will be noisy.....lay into it from a dead stop, if you now have power back and it shifts ok, it's the cat....
And remember to fix whatever caused the cat to go bad, like a misfire, bad O2 sensor, etc.
Old 09-10-2016, 05:39 PM
It lightly accelerates fine. shifts perfect. when i laid into the throttle it didn't go past 2500rpm. i'll try loosening the flange nuts next and see if that works. thank you very much
Old 09-10-2016, 07:42 PM
A990 racer
Or remove the egr.
Old 09-11-2016, 04:35 AM
Will removing the EGR valve have any negative effects?
Old 09-11-2016, 07:35 AM
Blue Bowtie's Avatar
Registered Offender
Remove the EGR as a method of releasing exhaust gas. it will be temporary ONLY, just like loosening the exhaust flange (if you can loosen the flange without breaking studs it will be impressive).
In order to prevent damage to anything keep wiring and hoses out of the way of the EGR port when test driving.
Incidentally, that "tick" could under load also be an exhaust leak.
Old 09-11-2016, 04:09 PM
Well. i tried all of the above and i even took the heads off and it doesn't look like i can find a diagnosis. CEL finally came on and it said map sensor so i replaced it. its better but it is still knocking and doesn't want to accelerate, not as bad as it used to be but still bad. engine is overheating and smoking. noise increases with rpm
Old 09-11-2016, 04:37 PM
Well. solved it guys. it's piston slap.
Tags
rpm
