I have an 88 Accord LX (carb), with an auto trans. I stripped everything out, and added a roll cage. I race it on a 1/3 mile oval asphalt track. Of course, there are rules, and I'm looking for ways to bend the rules. Last year I raced an 88 LXI (manual trans), and it was the fastest car in the class. I know this car won't go as fast, but would like to make it as close as possible. This is supposed to be a low-cost hobby, so I'm not looking to spend much money (if any at all). I already swapped engines because the original had a blown head gasket (supposedly rare for this car).
So far, one of the coils on the left-rear shock is cut, s the car leans slightly to the left. The toe is slightly adjusted in the rear to make it go around the track easier, and I've added a bar between the rear strut towers. The front-right upper control arm has been changed to allow slight adjustment of camber. I set the tire pressure the way I'm supposed to. I can't think of anything else to do to improve the handling on the track. I won't be able to get away with lowering it, or anything that noticeable. Also, I'm restricted to 75 series tires (14 inch wheels).
As far as the engine goes, all I did was put in a new thermostat, water pump, secondary fuel filter, and spark plugs. I removed the AC compressor and condenser. Understand that I know very little about cars. I can't believe I swapped the engine and it actually runs!!! If I could make it have more pickup, I'd be very happy.
Does anyone have any ideas? Any help would be greatly appreciated!
