Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Firebird Discussions
Old 06-26-2016, 07:40 AM
2000 trans am 2000 trans am is offline
headlight remote entry
this just started when I lock or unlock my door the headlight pop up & go back down must be a short or bad ground
any ideas
thanks
Old 06-26-2016, 12:34 PM
Blue Bowtie's Avatar
Registered Offender
Re: headlight remote entry
Is this an aftermarket remote entry/alarm system? If so, many of those have an option to flash the headlights and/or chirp the alarm to acknowledge the unlock command. If it is set up to do so that is why you lamp doors are opening/closing.
If this just started happening with the alarm system it is possible the programming or setup has changed to this mode due to a low battery, voltage transient, nearby lightning, or other cause of interference, or due to a poor power connection to the alarm unit.
Old 06-26-2016, 03:19 PM
original remote even does it if I lock the door on the arm rest
Old 06-26-2016, 03:44 PM
Registered Offender
Check the owner's manual for alarm setup. Some of that was done through the factory radio, and it may have been scrambled or reset to default.
