Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Off-Topic
Old 07-01-2003, 08:42 PM   #1
chris26969
Turbo Time
How long should I wait for a turbo to cool down before I shut off my car. I hear times of around 5 minutes. Any help would be appreciated.
Mods :
-3" Full Cat back exhaust
-K&N Filter
-MBC
-Upper Intercooler piping 1g Flange
-Turbo Intake
-BOV
-2 inch Drop
-Red/Orange paint job
-17" rims
-Indigo Gauges
chris26969 is offline   Reply With Quote
Old 07-01-2003, 08:46 PM   #2
Talon007
Talon007's Avatar
Send a message via MSN to Talon007
A good turbo timer shoud've been your first purshace along side the boost guage. They determine how long the car should run, and it will do it with the key out of the ignition, and arm your alarm when it shuts the car down.
But letting it run 5 minutes before and after should be good.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Talon007 is offline   Reply With Quote
Old 07-02-2003, 08:24 AM   #3
LandoAWD
Send a message via AIM to LandoAWD
If you stay out of boost, with little load on the engine for the last little while you drive, you should have no problem with oil coking.
Kris
2012 Genesis Coupe 2.0t
LandoAWD is offline   Reply With Quote
Old 07-02-2003, 09:59 AM   #4
turbo2nr
turbo2nr's Avatar
Send a message via AIM to turbo2nr
i say if you are running on boost b4 you shot off your car 5 min is good but if you are running off boost 2-3 min is good.
1
Shift_BOOST
97 s14
turbo2nr is offline   Reply With Quote
Old 07-02-2003, 10:21 AM   #5
LandoAWD
Christ dude, unless you drive around at 20psi, and whip into a spot with an e-brake, and kill the iginition, 5 mins is a little excessive. Remember, these things are water cooled as well....
Kris
Old 07-02-2003, 11:15 AM   #6
AeroEclipse
AeroEclipse's Avatar
Send a message via AIM to AeroEclipse Send a message via Yahoo to AeroEclipse
For normal drivnig i leave mine at 1min. 30 sec.
AeroEclipse is offline   Reply With Quote
Old 07-10-2003, 06:40 AM   #7
kjewer1
AF - Advisor
Back when I had an EGT guage I found that it only took a minute to get temps down to 500c (normal idle temp for my particular car, YMMV) even after hard driving. If you havent been boosting in the last few minutes of your drive, like my place, in a residential area, then just 20-30 seconds will do it.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
kjewer1 is offline   Reply With Quote
96 Eclipse RS 2.0 non turbo Timing donidavis Engine, Transmission and Drivetrain 1 01-17-2011 02:36 PM
Turbo Time HeyYou372 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 10-28-2003 11:41 PM
Turbo time integraGSR99 Street Racing 29 08-14-2003 03:04 AM
Turbo timing NA 3G eclipse Rtypespekz10 Off-Topic 3 07-31-2003 05:49 AM
Turbo Timing denjam69 Performance 6 11-15-2001 07:47 PM
