Go Back   Automotive Forums .com Car Chat > Racing > Street Racing
Old 08-07-2003, 04:17 PM   #1
integraGSR99
Turbo time
Just ordered the setup:
Eagle Pistons/rods, fuel pump, injectors, Apexi Power FC (w/remote), customer turbo kit (garett ball bearing) Customer intercooler, tial wastegate, BOV, clutch masters stage 3. Still need to get gauges and such....
Gonna run around 20-25 lb boost. Hopin for 400+ hp. and low 11's Will post picks when it's done (2 weeks or more)
integraGSR99 is offline   Reply With Quote
Old 08-07-2003, 04:22 PM   #2
integraGSR99
Currently
Oh yeah, currently have dc sport 421, greddy cat back, skunk2 intake man, skunk2 cam gears, AEM CAI, zex nitrous. On stock clutch w/55 shot 14.13 best ETA
Old 08-07-2003, 04:29 PM   #3
carrrnuttt
carrrnuttt's Avatar
Re: Currently
Welcome to AF and that's a nice setup.
Where are you located, and are you working on the motor yourself, or is it going to a shop?
2002_Nissan_Maxima_6-speed
carrrnuttt is offline   Reply With Quote
Old 08-07-2003, 04:59 PM   #4
integraGSR99
Going to the shop. Located in Oregon. I cant wait!!!!
Old 08-07-2003, 05:18 PM   #5
esp
esp's Avatar
Send a message via AIM to esp Send a message via MSN to esp Send a message via Yahoo to esp
Re: Turbo time
for some reason i dont think that with these mods you will be able to run that amount of boost.
*RIP* Integr8 aka Ryan *RIP*
5/29/03
www.fotki.com/esp
THIS OG IS GONE retired for good. peace yall. create a crew for me
esp is offline   Reply With Quote
Old 08-07-2003, 05:21 PM   #6
Neutrino
Yaya Master
Neutrino's Avatar
Send a message via AIM to Neutrino
very nice setup
quik question did you mean custom turbo kit and intercooler?
anyway short word of advice for high psi get a blueprint and balance job....that should make your engine buletproff....and don't cheap out and get a proper dyno tune....the power proper tuning gives you is amazing
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Neutrino is offline   Reply With Quote
Old 08-07-2003, 05:22 PM   #7
integraGSR99
The guy that is doing the work for me has done this several times before.He runs 30 lb on a very similar setup w/stock valve train and pushes 600+ hp. Oh yeah stock compression BTW. I've see the cars he's done with less mods running 25+ boost
Old 08-07-2003, 05:26 PM   #8
integraGSR99
Yeah I meant custom turbo kit. The turbo is garett ball bearing (don't know code for compressor), I don't know what kind of intercooler I am getting. Don't know what kind of BOV. We have been planning it out and I'm going tomorrow to order it (payday) I will know the manufacturer of everything tommorow when I order it. should be here by end of next week hopefully.
Old 08-07-2003, 06:24 PM   #9
maxspeedhonda
maxspeedhonda's Avatar
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Re: Turbo time
Not without a sleeved block you won't...for long that is....
maxspeedhonda is offline   Reply With Quote
Old 08-08-2003, 04:24 PM   #10
Ricochet
Banned
Ricochet's Avatar
Are you going to run nitrous with the turbo? My g/f's cousin has a turbo/nitrous GSR and he runs high 12's. I see mid to low 13's in your future, unless you spray and that may get you where he is. By the way a 580hp EK hatch with a turbocharged b18c1 runs 11's that I know of, so good luck in a heavier car with 180 less hp.
Ricochet is offline   Reply With Quote
Old 08-08-2003, 05:12 PM   #11
civicgsr_T4_60-1
Send a message via AIM to civicgsr_T4_60-1
I call BS right here. I'm not saying your not getting this work done. But i know personally what it takes to run this amount of boost. My Block is built to run that boost level. You may get away with close to 20psi on that setup but not more and not for long. The stock sleeves are good, but not that damn good on 10:1 compression which the gsr motor has. You will at least need a low compression headgasket. Also, I don't see any honda B series motor making 600+hp on a stock head, That's just crazy. I know guys with built heads that aren't making 600whp and are running mid to low 10's in their street car. I just hope you have alot of money because this guy seems to be feeding you some crap.
00 civic with bolt-ons, i swear
civicgsr_T4_60-1 is offline   Reply With Quote
Old 08-10-2003, 03:58 PM   #12
integraGSR99
Well, doesn't matter now. Instead of the turbo I bought an STI. No problem hookin up on the stock 13.1 1/4 mile. Won't take much to get into the 12's. Like to see a 400+ honda hook up on street tires. BTW if it is locked in AWD, it will not peel out. I had heard that it would burn all 4 tires in 3 gears, which is BS. When you put more power to the rear you can get a small burnout but nothing spectacular. The headlights are way cool! You can make them point down at the road, or straight ahead. Lots of bells and whistles on this car.
Old 08-10-2003, 05:26 PM   #13
carrrnuttt
carrrnuttt's Avatar
All this in THREE days?
Pics please, or don't bother posting about your new STi anymore. Nobody'd believe you.
Old 08-10-2003, 07:12 PM   #14
-The Stig-
On Fire!
-The Stig-'s Avatar
Send a message via AIM to -The Stig-
All balancing is checking for clearances... You have to do that anyways when building a motor. Its just a fancy word for checking numbers...
Balancing just helps the motor run smoother at high rpm... not really a performance adder... it just helps keep the motor from wigglin itself to death at speed...
EDIT: To the guy who was going for the Turbo setup and then randomly bought an STI...
You kept mentioning several times that you had to wait for money (payday) to order parts. Yet you just off and bought a STI?... I understand you probably financed it... but still that seems pretty Fishy.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
-The Stig- is offline   Reply With Quote
Old 08-10-2003, 09:48 PM   #15
maxspeedhonda
I find it amusing that when everyone calls BS, it's all of a sudden "well i got an STi." I thought he said he already ordered all this stuff. I suspect this is the kind of person that gets "crazy boost" from their electric turbocharger and BOV simulator. Well hurry out and find some cool STi pictures on the net and post them as your own that that you can impress an anyomous internet community.
96 Eclipse RS 2.0 non turbo Timing donidavis Engine, Transmission and Drivetrain 1 01-17-2011 02:36 PM
Turbo Time HeyYou372 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 10-28-2003 11:41 PM
Turbo timing NA 3G eclipse Rtypespekz10 Off-Topic 3 07-31-2003 05:49 AM
Turbo Time chris26969 Off-Topic 6 07-10-2003 06:40 AM
Turbo Timing denjam69 Performance 6 11-15-2001 07:47 PM
