Old 07-01-2003, 07:35 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Flush-mount tweeter placement
Just picked up a set of Focal Polyglass 165 V2 component speakers, and I'm going to install them soon...
What would be the best placement for the tweeters?
Also, where should I mount the cross-overs at? The only place that I can think of that has enough clearance is where the door-mounted seat-belts used to be before I took them out... Either that, or maybe under the dash somewhere, but I don't want them to be too far from the speakers, so I don't know how well that would work...
Old 07-01-2003, 07:53 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
I would talk to 4G4DStore (Nick) and ask him. He has Phoenix Gold components in his front doors (sedan), so obviously he found a place for the crossovers.
Old 07-01-2003, 08:09 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
my crossovers where huge i just put em under the seats
i put the tweets about an inch away from the doorhandle toward the front of the car
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 07-01-2003, 09:17 PM
ci5ic's Avatar
Here's a pic...
Old 07-01-2003, 09:24 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Is probably not the best place for them, but in my brothers 91 I installed the crossovers right behind the CD player under the dash... lots of room back there.
As for the tweeters, I mounted his in his dash right in the corners up close to the window.... wasn't too bad of a spot to mount them, although with them playing so much closer to your ears then the woofers you have to turn the treble down a good bit unless you like an overly high pitched sound (guitar solos sound bad ass though)... other then that, I would mount them as close to the woofer as possible and aiming up towards the head rests so as to best target your ears.
Honda Enthusiast
Old 07-01-2003, 09:30 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
a good spot my friend uses is at the bottom of the A-pillar where it meets with the dash.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-01-2003, 10:14 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
look for kick panels that's got the whole deal made for you, you can fit the mid and tweeter right in, it goes down by ur feet, right under the hinge-area
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 07-01-2003, 10:36 PM
ci5ic's Avatar
Nah, I don't want kick panels... I want the speakers in the door... I'm making some fiberglass door-pods for them, but the tweeter is going to be mounted higher.
Old 07-01-2003, 10:38 PM
AirAllen01's Avatar
AirAllen01 AirAllen01 is offline
Send a message via Yahoo to AirAllen01
I've got a set up like that. Place the crossover behind the door panel, and the tweeter at the top corner of the door panel under the window towards the front.
Have you ever danced with the Devil in the pale moon light?
I'm your Huckleberry.
Don't hate the playa, hate the game.
Unreal Tournament 2004 Mexican Mafia «MM»Sternum
Visit AF's Sketching and Drawing Forum.
http://www.automotiveforums.com/vbulletin/f1155/
Old 07-01-2003, 10:49 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
This is an old pic...tweeters were placed just a couple of inches in front of the door handle and the 6 1/2 inch woofer were in the stock speaker location...crossovers were strapped inside the door panel.
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 07-01-2003, 11:14 PM
AirAllen01's Avatar
Exactly what I said....thanks for the pic
Old 07-02-2003, 01:59 PM
ci5ic's Avatar
I think that's exactly what I'll do... put the tweeter just in front of the door-handle like that...
Next question:
How did you cut the holes for them? I was thinking of buying a hole saw bit for my drill and using that... Any thoughts?
Old 07-02-2003, 03:57 PM
AirAllen01's Avatar
You might try a Dremel tool. Or you could use a drill bit to start the center and a skill saw to cut the hole, then use a sander bit in the drill to smooth the edges.
Old 07-02-2003, 05:26 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i find that pic i told you i had earlier
the thing with mine is they are 2 1/2" 2 way tweets. they sound kick ass BUT, the mounting was tricky. to mount they have that big as plactic nut you thread on. that was the only spot in the door where it was deep enough and that plastic nut wouldn't hit.
be very selective where you put it. check, double check, hell triple check the spot. i assume those are your original panels and it would suck if something bad happened to 'em.
ps. jer was extremely smart. i give him an A+ for effort. when he bought the componet set he got a 2nd pair of the tweets...that way if one ever goes bad i have another for the big ass hole in the door
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 07-02-2003, 06:08 PM
el_loco_civic's Avatar
el_loco_civic el_loco_civic is offline
Send a message via Yahoo to el_loco_civic
Reading Audio Mags for awhile now, and i've learned the most recomended place to mount tweeters is on those pillar things that are on either side of your windshield. Its very easy to make em' fit too. . i have mag' articles but no scanner.. all they did.. was cut hole for tweeter, get bondo and Kitty Hair ( Long fiberglass strands ) And make yer desired shape . . and so on.. Yea, i'd do the crossovers in the door panels also..
PS: are those Digital Audio ??
Civic - Trashed it
Integra - Hit and run totaled my ride after a couple 360*'s.. hittin guard rail at 80mph, literally FLIPPING over guard rail, barrel roll 2 more times, crashed front into a tree..
New Plans : Teggy / or / Tiburon
Mounting Tweeters pbcdb Car Audio 9 11-29-2004 12:48 PM
mounting tweeters hightek Accord/TSX/Accord Hybrid 1 11-19-2004 12:06 AM
Mounting tweeters. Need advice Tony '88 - '91 Civic | CRX | Wagon | Shuttlee 15 02-02-2003 06:55 PM
