Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 06-09-2016, 09:44 AM
Blakes7 Blakes7 is offline
1996 Corolla Won't Start
1996 toyota corolla 5-speed 1.6 engine
Hi! I have a 1996 toyota corolla. It's a 5 speed. I had been driving for about a half hour with the a/c running, stopped at a store, came out and the car wouldn't start. The starter turned over, but it wouldn't fire---didn't even attempt to fire. It was running fine before I stopped. I had it towed to a friend who does mechanic work. We've replaced the distributor and the ignition module, but still can't get a spark at the plugs. Any ideas why it won't get a spark to start? Any and all responses will be greatly appreciated. Thanks.
Old 06-09-2016, 10:30 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 1996 Corolla Won't Start
If you have an external ignition coil, I would replace that. Testing a coil is potentially meaningless unless it tests bad.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-26-2016, 09:33 PM
Keg914 Keg914 is offline
I second the ignition coil check. I had a similar problem on a 95 Corolla.
