Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-21-2016, 03:43 PM
94HeavyChevy 94HeavyChevy is offline
8.5 rear end
Looking for a complete 8.5 rear end to put in my 94 caprice 5.7. Anyone have one or know a good place to get one? Local used parts/junk yards around me want 400-700 bucks for them and can't tell me what kind of gears they have.
Old 02-21-2016, 07:35 PM
Blue Bowtie's Avatar
Registered Offender
Re: 8.5 rear end
If the axle is original in the vehicle you can open the trunk to look for the SPID label.
G80 is limited slip.
GU4 is a 3.08 ratio. That would be in an SEO vehicle or impala SS.
GM8 is a 2.56 ratio. That was standard,
GW9 is 2.93 ratio. Those were options in tow packages.
Old 02-21-2016, 08:39 PM
Re: 8.5 rear end
Vehicle originally was the 4.3L V8 and has the 7.5 rear end with 2.73s. Looking to swap a 8.5 in it!
Old 02-21-2016, 10:15 PM
Registered Offender
Re: 8.5 rear end
Your closest choice of LT1 axles would be the 2.93, but those are fairly rare. 3.08s are the next toughest to find but would be an improvement for the L99. A 2.56 could be quite a load for the smaller displacement. In any case the PCM would require a reflash to get the speedo and shift points correct.
Old 02-22-2016, 07:03 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 8.5 rear end
Just to add to the above - the '94-'96 9C1 Caprice will generally have the 3.08 ratio axle, but this will also have disc brakes vs. the car you have (drum brakes).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
