Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 02-11-2016, 11:41 PM
automan9482's Avatar
automan9482 automan9482 is offline
Send a message via Yahoo to automan9482
2000 Tacoma Dexron III equivalent??
2000 Tacoma SR5 Xtracab 2.4L 5 spd 119k.
Just purchased this about a month ago, and was going to do a power steering fluid change.
The owner's manual calls for Dexron III ATF as the power steering fluid. I know this has been superceded, and found many confusing equivalent choices at da parts store. I stared at my choices for about 10 minutes and settled on Castrol Transmax Import Multi-vehicle ATF. It doesn't specify use for Toyotas calling for
Dexron III, and neither did any of the actual PS fluids. The newer versions of Dexron didn't specify compatability with Dex III either. Before I dump it in, I want to make sure it is compatible, and I trust this site more than the guy at the parts store...bc...well. Thanks in advance!
Sent from a rotary phone via Edna the Small Town Operator.
Old 02-12-2016, 07:45 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 2000 Tacoma Dexron III equivalent??
It will work fine.
From the Castrol website:
Castrol Transmax™ Import Multi-Vehicle Automatic Transmission Fluid is for use in most Honda, Toyota, Nissan and other imported vehicles. It exceeds the requirements of the JASO -1A performance standard created by Japanese Automobile Manufacturers. This standard is recognized by Japanese OEMs in certifying ATF for use in their vehicles.
Warranty and Protection Requirements
Exceeds all passenger car and light truck manufacturer’s warranty requirements for vehicles, transmissions or power steering service where a DEXRONŽ-IIIH, MERCONŽ or MERCONŽ V type ATF is specified
Industry Specifications and OEM Approvals
Meets or exceeds General Motors DEXRONŽ-IIIH requirements
Meets or exceeds Ford MERCONŽ V and Ford MERCONŽ requirements
MERCONŽ V approved and licensed by Ford Motor Company
Meets or exceeds JASO-1A requirements
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
The Following User Says Thank You to Brian R. For This Useful Post:
automan9482 (02-15-2016)
