Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 12-05-2015, 01:54 PM
andymikem97 andymikem97 is offline
Fuses blowing, now windows dont work
On a 2001 tacoma, 6 cyl ext cab. I had an issue where multiple fuses would blow continually. That issue stopped, went away on its own. But now the power windows won't work and that fuse is fine, changed it just to be sure anyways. Dealer tells me it needs an ecu and harness (since you can't buy JUST the ecu). $5500 for this? The whole truck isn't worth half that. My gut tells me they are just screwing me around. Has anyone ever encountered anything like this?
Old 12-05-2015, 02:44 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Fuses blowing, now windows dont work
I would try replacing the power wire going from the positive battery terminal to the fuse box. If it is corroded or damaged, it may cause some weird symptoms.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 12-05-2015, 03:02 PM
I can give that a whirl, but it's only affecting the power windows? All 4 of them? So weird.
Old 12-05-2015, 09:52 PM
MikeCStig MikeCStig is offline
You may have a bad ground somewhere, or just a short in the wiring harness. Either can be repaired without a whole new ecu or harness. Somebody's definitely trying to f*ck you. Go somewhere else
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 12-06-2015, 07:16 AM
There's an electrical shop not too far from the house. I'm hoping they can help me trace the wires in the harness. I'll post back.
