Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-22-2015, 03:02 PM
ngn90 ngn90 is offline
muffler question
Hi,
I was recently given a 1999, 6 cylinder, Camry that needs a new muffler. After taking a look at it I could see it's it's bolted on. Are they bolts, or studs welded on to the muffler, or what are they? Whatever they are, they need to be replaced. If they are a separate part, what should I buy?
Old 11-22-2015, 03:49 PM
MikeCStig MikeCStig is offline
Re: muffler question
Can you post a pic?
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 11-22-2015, 04:58 PM
I don't have a digital camera, but I found this video on youtube: https://www.youtube.com/watch?v=7M6uH1hnNgQ
Everything is the same. Here's a screen capture.
Thanks for your help.
Old 11-22-2015, 10:23 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
They are welded-on studs.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
