Old 06-30-2003, 04:18 PM
Dragonscatcher35 Dragonscatcher35 is offline
Still having problems with idling on 67
I have done a tune up on the engine, but I still can't get the engine to idle. It sounds alot better now with the tune up, but as soon as I let off the gas then the car will die. I've monkeyed with the timing but still noting makes a difference. Any advice? Thanks
Old 06-30-2003, 06:21 PM
tazz3 tazz3 is offline
did u change the points and the condesner.
if u have a older distoaour u might have points.
when i had my chevlle a few years ago i use to go thought ponits
Old 06-30-2003, 09:06 PM
change the points and dispensor? I only know the basics about cars. Can you walk me through this please. Thanks
Old 07-01-2003, 07:00 PM
ok this is going to be kinda hard to walk u thought this.
but frist u have to find out what kind of ingintion u have.
is it a newer one,
or a older one with points
frist u have to find out about the ingnition.
Old 07-01-2003, 08:43 PM
orangecamaro orangecamaro is offline
Banned
gaskets
You should replace the gaskets, i know when i had mine doing that i changed the valve cover gaskets and exhaust gaskets and it has worked fine ever since.
Old 07-02-2003, 12:52 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
what the hell are you talking about "orange camaro"?
Old 07-02-2003, 11:00 PM
the car doesnt have points i know that now.....
Old 07-03-2003, 04:56 PM
meanpeoplesuck meanpeoplesuck is offline
Banned
you have a zip lock
There is a zip lock in the gas line going to your carb and its gettting air in thieir. bleed all the gas and put a little carb cleaner in your system and it will help. If that dont help, change the fuel filter in your gas line.
Old 04-14-2004, 12:20 AM
fresdar fresdar is offline
Send a message via Yahoo to fresdar
Re: Still having problems with idling on 67
check the rotor and cap. but if your getting good fire to the plugs then your carb may need to be adjusted. if the car has set for a long time then the carb might need a carb kit. also if you have ever flooded the engine then changing the plugs would be a good idea.
Old 04-14-2004, 01:29 AM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
y dont you just play with the idle screw on the carb?????
Old 04-14-2004, 10:07 PM
96Civ's Avatar
96Civ 96Civ is offline
And maybe the mixture while your at it.
still having problems with fuel pump oops-sorry Trans Sport 1 04-23-2006 07:29 AM
Still having problems with Tracker dying Txsbigfoot Tracker 1 02-07-2006 05:59 AM
still have problem with dash please help ? rlkolomitz Aurora 1 05-12-2005 09:24 PM
Still having problems with Taurus! cellist Taurus | Taurus Wagon 2 02-16-2005 11:43 PM
still having problem with shutting off wally91vhevrolet C/K 4 11-15-2004 04:55 PM
