Old 06-30-2003, 01:46 PM
dudez316 dudez316 is offline
TAMIYA Rubbing Compound
What EXACTLY is Tamiya Rubbing Compound for, and why do people use it? Cant you just skip the compound and go strait to wax?
Old 06-30-2003, 02:21 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
It's an abrasive polish, more pure than automotive polishes. Think of it as a liquid form of very high grit sandpaper that is in a paste-like carrier. You apply it to a clean cotton cloth and rub down the paint to smooth it out by smudging the paint around (quite literally).
Toothpaste does the same thing for your teeth in that its a paste or gel with an abrasive in it to break down the rough plaque that builds up on your teeth.
You can actually use toothpaste as a polish for your cars if you can find something that doesnt have all the additives of new toothpastes.
Old 06-30-2003, 03:16 PM
G60 Kid's Avatar
G60 Kid G60 Kid is offline
It will also turn a Semi-Gloss finish into a High Gloss finish. Trust me
Old 07-01-2003, 03:03 AM
primera man's Avatar
"P-Man"
How do I polish the body?
How to use rubbing compound and wax to polish a body
View All My Models Here.
Old 07-01-2003, 02:41 PM
fatboyslim's Avatar
fatboyslim fatboyslim is offline
But if you live in the UK don't even bother trying to find Tamiya Compound or Polish as it isn't even imported here by the importers!!
DAMN THEM!!
See my models, click on HOMEPAGE below
Old 07-01-2003, 03:29 PM
Thor302's Avatar
Thor302 Thor302 is offline
i had to special order a tube from japan through my hobby shop but it was well worth the wait!!!! its great if you use like duplicolor or krylon because you can get a laquer like paint job for cheaper, but use it on tamiya laquer and its fabulous, also final touch wax is awsome!!! sorry for babbling on.......
Old 07-01-2003, 04:16 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
hm, i just tried colgate toothpaste, then applied some green turtle wax, and it made it shiny-er, not as good as it should be, atleast its better.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
tamiya rubbing compound fine geckoman1220 Car Modeling 9 05-02-2008 12:21 PM
is Tamiya rubbing/polish compound only for acrylic paint jobs? dgdarien Car Modeling 13 06-25-2007 02:10 AM
Tamiya Rubbing Compound Question chato de shamrock Car Modeling 10 02-11-2006 02:07 AM
Tamiya Rubbing Compound - a confession. Guido Car Modeling 13 03-09-2003 09:04 AM
Tamiya Rubbing compound ruffman Car Modeling 5 09-15-2002 10:55 AM
