Old 06-30-2003, 09:28 AM
Type-Racer Type-Racer is offline
heated oxygen sensor
i recently pulled the codes using the service connector and got 41.i think this is the heated oxygen sensor circuit.is this the primary or secondary sensor and where are they located?if it is the sensor where can i get one?the car is a Honda Civic 1999 DX.the sensor has four wires.could i use a universal sensor?the car is really riding rough.
Old 06-30-2003, 09:23 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Bosch makes a universal sensor but it is kinda rigged looking to me, I would just get the one that has the connector on it to fit your car. Just my opinon though.
Old 07-03-2003, 04:00 PM
jeffseby's Avatar
jeffseby jeffseby is offline
Send a message via AIM to jeffseby
GO ON EBAY
Old 07-04-2003, 02:08 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
You need to get a manual and troubleshoot it before buying something you may not need. A 41 is a failure in the Ho2 circuit, it is the same code you throw when you swap a B series into a 5th gen VX, it is because the wiring is different in the VX and the power source is in a different pin. So you should find out what is really wrong before, just replacing the o2 and then finding out it was something else.
Oxygen Sensor sasheehan Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 6 04-01-2012 08:19 PM
Need help w/Heated Oxygen Sensor Dan A GS300/GS400/GS430/Aristo 0 03-27-2005 04:34 PM
Heated Oxygen Sensor johnb_009 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 02-24-2005 11:18 AM
Throwing P1132 and P1152 Lack of Upstream Heated Oxygen Sensor Switch codes MeanWS6 Taurus | Taurus Wagon 0 08-31-2004 09:41 PM
Heated Oxygen sensor Malfunction mannella9 Taurus | Taurus Wagon 5 01-26-2004 07:24 PM
