Old 08-31-2004, 09:41 PM
MeanWS6 MeanWS6 is offline
Throwing P1132 and P1152 Lack of Upstream Heated Oxygen Sensor Switch codes
Today my 2002 Ford Taurus (winter beater) started idling rough and throwing codes:
P1132 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P1152 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
I also noticed a slight “air hissing” sound coming from down by the brake pedal when I apply the brake. And when I listen under the hood the air sound (sounds like a vacuum leak) seems more apparent.
Now, (not sure if related or coincidence) but this all started happening AFTER I had my alarm/remote start installed today. I looked everywhere to find out where the sound was coming from but no dice. I am taking it back tmr to see if they can figure it out. Again, not sure if this is related.
Any ideas what could be causing this?
I tried the carb cleaner trick around all the hoses and intake gaskets, with no results. They all seem to be entact.
1999 WS6 Convertible #3599
Cartek Stage II-X Heads
G5x2 Cam
Maximum Evil Stage III Trans
Yank PYE3600
Moser 12 Bolt / 33 spline / 3.73’s
NXL Direct Port Nitrous (180 shot)
Bunch of other stuff . . . .
Dynoed: 415rwhp NA
No track times yet
2002 Ford Taurus SE (winter beater)
