Old 06-30-2003, 05:44 AM
xlosinghopex xlosinghopex is offline
Send a message via AIM to xlosinghopex
93 octane limits
I'm thinking of getting higher compression pistons for my b16a. How high can I go running 93 octane?
Old 06-30-2003, 12:54 PM
94civic's Avatar
94civic 94civic is offline
probably around 11.5:1 just to be safe you can probably run 12:1 with an octane booster or extra fuel and retard the timing.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 06-30-2003, 02:39 PM
Any idea how much power 11.5:1 would produce in a b16a? What about in addition to that boring the cylinders out to 1.8 liters?
Old 06-30-2003, 03:16 PM
94civic's Avatar
i don't know how much power it will get you. i got some ctr pistons and i'm going to match them up with some eagle rods and ACL bearings(same type used in f1 racing) with a mugen headgasket and the compression ratio was around 11.1:1 so i'll let you kow once i get it done.
too much to list
Old 06-30-2003, 06:50 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
im running the CTR pistons and eagle rods too, comp ratio in the b16a should be around 11.5:1
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-01-2003, 03:18 PM
94civic's Avatar
what kind of head gasket are you using if its a one layer then yes if it a 2 layer then it should be aroung 11.1:1.
too much to list
Old 07-01-2003, 09:29 PM
crxlvr's Avatar
mine is 1 layer
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-02-2003, 02:30 AM
A gasket is another part I was thinking of getting to raise compression but I haven't looked into it much. Are there only 1 or 2 layer options? Are the thin ones less reliable? Also what brands make the thin ones?
Old 07-02-2003, 04:45 PM
94civic's Avatar
spoon, mugen,toda, mr. gasket, and there are some more.
too much to list
93 Octane VS. 87 Octane Gas freesiagirl Metro 4 09-03-2007 05:11 PM
91 octane limits compaqpunch 3000GT/Stealth 6 02-02-2007 12:24 PM
Is 87 octane gas with octane booster as good as 93? Spectre120 Camaro Discussions 28 10-20-2004 05:51 PM
87 octane in 93 octane required car ZachE84 Engineering/ Technical 11 10-10-2004 02:50 AM
Octane Boosters and 89 or 93 octane gas blazzingbrandon 4Runner/GX470 2 08-29-2004 02:02 AM
