Go Back   Automotive Forums Car Chat > Toyota > Previa
Old 03-12-2015, 07:32 PM
lwf999 lwf999 is offline
Smile Can anyone give me some suggestion about my previa had just fail smog check ? please please please ...
My Van just failed smog check from comprehensive visual inspection and functional check . and i took my Van to technical they help me to fix the engine light but my van had oil leaking underneath so will that be another problem that will failed again even i fix my engine Light because the Engine light used to stay on while driving but just burn out when i go smog check and it said ODB system check Failed and Other emission component Fail . i need some advice before i go retest .Pleaseeeeeeeeeeeeeee
Old 03-14-2015, 12:35 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Can anyone give me some suggestion about my previa had just fail smog check ? please please please ...
Bring your van to a mechanic whom you trust. Get a recommendation from a co-worker or relative. Tell them to diagnose your engine and repair the failed part causing the check-engine light to come on.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 03-14-2015, 02:44 PM
they checked the engine light for the code said relate it to catalytic converter but my VIR said my catalytic converter test passed i am so confusing .
Tags
check , smog
